pcm controlled e-fans?
Old Mar 17, 2005 | 10:28 PM
ok i dont know what i did wrong buut i used pin 42 and put all the settings in and the fans will come on all the time but only when the engine is running with koeo the fans are off it seems like whenever the pcm sees tach signal it turns the fans on
Old Mar 17, 2005 | 10:46 PM
Flyer's Avatar
Originally Posted by greentahoe
Sorry to bring this up from the dead, but Id like to set some LS1 fans to come on with HPTuners. I see the settings mentioned, but what about the
VATS Control
Serial
PWM
None.... is default
Ignition Off
Disable temp ?
Run Time ?
And what about AC settings?
Thanks alot
Disable temp should be set to ~177 (5* lower than the shutoff temp)
and run time set to however long you want the fans to continue running once you shut the engine off.
Avalanche2002
Nov 30, 2015 07:31 AM
turbo6c3
Oct 5, 2015 06:11 PM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
