Pacesetters vs ET reduction
Old May 27, 2005 | 12:05 PM
shandy294's Avatar
Default Pacesetters vs ET reduction
With truck in sig and 15 to 20 hp gain from the LTs can I expect any reduction in et?
Old May 27, 2005 | 12:20 PM
TXsilverado's Avatar
yep. make sure and get a good flowing exhaust like magnaflow or dynatech to complement the headers and intake
Old May 27, 2005 | 02:15 PM
Gran Patron's Avatar
You should see some improvement not much but it will help your E/T times.
If you're running high 16's now you should dip to the low-mid 15's.
Old May 27, 2005 | 03:15 PM
shandy294's Avatar
I ran a best of 16.12 in January. I don't expect the headers and possible change to the rest of the exhaust syatem to yield more than a tenth or 0.15 sec reduction. Would you agree?
TxSilverado...thanks.
Old May 27, 2005 | 03:50 PM
BLACKND's Avatar
It possible with a full exhaust. Just swapping in headers I wouldn't expect too much. You would see a gain in the top end. I did my headers at the same time as my cam and I picked up about .5 in the 1/4 mile. Although I had already had a full custom exhaust and tuning and just about every other bolt on also. Plus the air temp was about 20 degree higher and the humidity was higher on the later runs. So I may have picked up about .6 in the 1/4 with headers and cam. I would expect about .1-.2 with just headers and maybe .3-.5 with headers and exhaust. But these are just guesses, just about every truck reacts differently to mods.
Have you done any tuning? Might want to look at exhaust and tuning before headers. Sometimes a little tuning can be required to run headers also, and would most likely produce better gains.
Old May 27, 2005 | 04:09 PM
I agree, shouldn't be that much decrease in time, but it helps.
My thoughts exactly on what Sierra Crew said!!!
Old May 27, 2005 | 04:20 PM
shandy294's Avatar
Thanks guys...I do plan on a Nelson tune sometime...tune,headers,fans,maybe something to help traction is about all I have planned.
Old May 27, 2005 | 04:53 PM
lotsofhp's Avatar
13 Second Truck Club
cibolo huh? I live right up the road from you in Garden Ridge.
Old May 27, 2005 | 05:31 PM
shandy294's Avatar
I'm in Northcliffe off FM 78 just S of I-35. My truck is bright red with no trim.
Old May 27, 2005 | 09:15 PM
white1's Avatar
Allyou have planned hugh? Yea right All I want is 14's but I'm in the 15.5's now, and need a cam,tune, and exhaust. Hopefully that will put me in the low 14's. Then I'll need a stall, and headers. If that puts me real low 14's then I'll HAVE to hit 13's. See where I'm going with this? If you can stop with just a FEW mods, you are a LOT stronget than 90% of the people here.
blown02408
Feb 24, 2016 04:50 AM
Cowboy Tom
11
Sep 16, 2015 09:35 AM
bisqikss
Sep 8, 2015 03:35 AM
USMCvet0311
Sep 4, 2015 09:43 PM
Sjeverette3
Sep 2, 2015 01:32 AM
