P0343 code after z06 cam install?
Old Apr 28, 2008 | 07:26 PM
2ktransam's Avatar
Originally Posted by thunder550
Did you clear the code after you changed out the sensor?
Yep, over and over and over again. I logged the cam output and it is not reading anything at all. Help!
Old Apr 28, 2008 | 09:40 PM
thunder550's Avatar
High on diesel fumes
Maybe a shorted or cut wire?
Old Apr 29, 2008 | 11:39 AM
budhayes3's Avatar
PT's Slowest Truck
The cam sensor gets it's signal off of the camshaft correct? Is it possible that the camashaft is damaged, or possibly that the cam is walking? I'd think that you'd get some signal from it, but if the magnet in the sensor isn't picking up the cam, it may read 0...
Old Apr 29, 2008 | 04:24 PM
2ktransam's Avatar
Well I found the problem. I pulled the cam out and it doesn't have a reluctor ring at all. I have no clue what this cam is for but it doesn't seem like it's the right cam for my truck. I should have noticed the difference but I didn't lay them side by side so I didn't know to look for it.
Old Apr 29, 2008 | 04:35 PM
thunder550's Avatar
That would do it...must be an LS2 style cam.
Actually, I bet it's a stock LS2 cam. That would be my guess.
Old Apr 29, 2008 | 06:35 PM
Truckshop's Avatar
yep. ls2 cam i have one in the shed. they have similar specs to an ls6 cam. the cam sensor on a ls2 reads off of the cam sprocket.
Old May 1, 2008 | 03:45 AM
viciousknid's Avatar
Where's the Beef?
Could just shut the sensor off I guess?
Old May 1, 2008 | 07:18 AM
2ktransam's Avatar
I don't know if you can do that or not. The cam is already out and a new one will be here tomorrow so I will have back up and running on Saturday.
ARC
57
Feb 21, 2022 10:54 AM
all_individual
Oct 10, 2015 10:09 PM
lxcoupe
Jul 30, 2015 02:42 PM
all_individual
Jul 13, 2015 11:01 AM
GreyChevy
Jul 7, 2015 08:57 PM
