p/v issues
Old Feb 22, 2005 | 11:49 PM
02sierraz71_5.3's Avatar
Default piston to valve
Anyone ever had any piston to valve clearance problems with milled heads, larger valves and a cam over .550 lift.
My heads have .050 off and 2.00/1.55 valves the cam is a 222/222 .566/.566
going on a 5.3 just wondering what everyone thinks and if I should purchase a flycutting tool for when the heads are off. I cant afford to ruin this motor. Im having someone else do the install and Im a little weary about it.
Whats minimum safe clearance?
are the 5.3 pistons dished?
I hate having other people work on my truck but I dont have a choice.
Old Feb 23, 2005 | 12:30 AM
PappyDan's Avatar
Tribe Shaman
yes the 5.3 has a dished piston, the 4.8 is a flat top.
i don't know how much you had the heads milled, or what brand of gasket your going to use to put back togather with.
i think you will be ok.
Old Feb 23, 2005 | 02:44 PM
tdrumm's Avatar
How much are the 5.3 pistons dished?
Old Feb 23, 2005 | 04:44 PM
good question Id like to know too
Old Feb 24, 2005 | 01:01 AM
bump bump
Old Feb 24, 2005 | 09:44 AM
tdrumm's Avatar
Some one has to know.
Old Feb 24, 2005 | 05:16 PM
tdrumm's Avatar
Ok, so what I read in "How to build high performance ls1/ls6 v8s" is that all gen III engines have flat top pistons with no valve reliefs.
Old Feb 25, 2005 | 01:45 PM
there arent valve reliefs on the 5.3 but instead a dished piston, the 4.8 have flat tops theres a good article around on the differences between the 4.8 and 5.3 it shows the top of the piston.
Or if you want just take a plug out and shine a small light in there look at the top of the piston and it will tell you
Old Feb 25, 2005 | 05:09 PM
tdrumm's Avatar
Do you have a link to that article? Everything I find says that they are flat top. Not dished.
I'd really like to know for certain because I want to add 1.8 rockers with my cam so I'm worried about p to v also.
Old Feb 25, 2005 | 05:38 PM
Hawk179's Avatar
Can I ask why you decked the head .050???????
If you wanted to add compression, then either do it in the pistons, or change the castings.
Rick
