p/v issues
Old Feb 25, 2005 | 05:45 PM
jmproductions's Avatar
Originally Posted by 02sierraz71_5.3
there arent valve reliefs on the 5.3 but instead a dished piston, the 4.8 have flat tops theres a good article around on the differences between the 4.8 and 5.3 it shows the top of the piston.
Or if you want just take a plug out and shine a small light in there look at the top of the piston and it will tell you
So if you put a 5.3 crank in a 4.8, it would raise the compression and/or create valve clearance issues. Does anyone know how much compression change?
Old Feb 25, 2005 | 06:34 PM
The 5.3 dish is -5 cc.
Old Feb 28, 2005 | 11:16 PM
02sierraz71_5.3's Avatar
Originally Posted by Rick@Synergy
Can I ask why you decked the head .050???????
If you wanted to add compression, then either do it in the pistons, or change the castings.
Rick
milling the heads is the cheapes way I would of had to pull the whole engine to change pistons or castings
Old Feb 28, 2005 | 11:19 PM
It wouldnt change the compression it would just lengthen the stroke and increase the cubes since the bore is the same on both engines. Compression is a figure computed when the piston is a top dead center, has nothing to do with displacement.
Old Feb 28, 2005 | 11:20 PM
thanks 6.0
where did you get that info from Id like to read on it. Im wondering why gm did that Im guessing to keep compression down?
Old Feb 28, 2005 | 11:23 PM
what the minimum clearance on piston to valve?
Old Feb 28, 2005 | 11:27 PM
GREGGO's Avatar
Ican verify that the 4.8 pistons are flat. I blew one up and had it torn down. Also, the 6.0 pistons are dished as well. Got 8 of those sitting in the shop.
Idryfly5
Sep 2, 2022 08:55 PM
murderedSS
27
Oct 12, 2015 11:13 AM
TAPyvehc93
Sep 14, 2015 01:22 PM
dselby25
Sep 11, 2015 05:03 AM
Boyes50
Sep 8, 2015 12:06 PM
