Overheating issue
Old Sep 6, 2010 | 06:48 PM
CHILLLLLL's Avatar
formerly Stroked-DSM (11/24/2010)
Default Overheating issue
Just picked up a truck yesterday from a fellow member on here. The truck went from Alabama to Florida (~490 miles) with ZERO problems. I got the truck home, took a few people for rides, then proceeded to go out for the night. Got a block away from home and the truck started to overheat. I shut it off and pulled over, let it cool off then went back home.
Replaced the thermostat, coolant temperature sending unit, and water pump today with no luck. When it stops raining I'm gonna see if there is air leaking in around an injector, maybe causing the truck to run lean and heat up. In the meantime, anyone have any suggestions? I'm kinda stumped.
Old Sep 6, 2010 | 06:53 PM
ap2002's Avatar
Does it heat up while u cruising or in stop and go traffic?
Old Sep 6, 2010 | 07:11 PM
CHILLLLLL's Avatar
It heats up in my driveway, and while driving. Like I said, it made it ~490 miles yesterday without any problem, both highway and city driving.
Old Sep 6, 2010 | 07:31 PM
THE-HOE's Avatar
does the truck have a stock clutch fan? Is the fan working correctly? if the clutch goes bad they will overheat at idle, but usually when driving the cool air through the radiator cools it back down.
Old Sep 6, 2010 | 07:32 PM
ap2002's Avatar
Samething happen to my brothers truck last month, it ended being the radiator, it was plugged/clogged up, took it off and had it cleaned up for about $60
Old Sep 6, 2010 | 07:36 PM
CHILLLLLL's Avatar
The truck has e-fans. I stuck a hose in the radiator with the upper/lower hose off but it didn't do anything. Maybe I'll take it off tomorrow and bring it somewhere to get cleaned up nicely.
Old Sep 6, 2010 | 07:45 PM
Truckshop's Avatar
are the fans running when it is overheating?
Old Sep 6, 2010 | 08:09 PM
CHILLLLLL's Avatar
Yes the fans are on. I just flushed the system to make sure there were no air bubbles and when I ran the truck with the overflow cap off the upper radiator hose stayed cold. Truck was hovering around 190* When I put the cap back on the temp of the truck climbed and the hose got hot. The radiator is also cool to the touch.
Old Sep 6, 2010 | 08:12 PM
ap2002's Avatar
My brothers truck had all water and no antifreeze when he bought it, so thats probably what caused it
Old Sep 6, 2010 | 08:26 PM
00buckshot's Avatar
Turbo truck?
