Overheating at Idle
Old Aug 18, 2006 | 09:18 PM
  #21
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Interesting. Makes think about flushing and refilling, but... hmm... dunno.
Old Aug 19, 2006 | 08:34 AM
  #22
hey, whatever is working for you at the time, if its cooler stick with it. just cuz statistics are not favoring your situation, you could be a freak.
Old Sep 26, 2006 | 05:33 AM
  #23
V8 Supra Builder's Avatar
Sounds like it got hot enough to boil away some of the water, which led to overheating, which probably won't happen with the Dex-Cool in there. Perhaps it was cooler outside when it didn't overheat? Intermittent problems are a pain. Glad it is OK now!
Old Sep 4, 2017 | 02:56 PM
  #24
erikk's Avatar
Registered User
on the overheating problem.. i got a new fan clutch, thermostat and radiator.. no leaks n waterpump looks pretty new.. what else could it be. it only does it sumtimes..
Old Oct 2, 2017 | 05:00 PM
  #25
ACAMS's Avatar
The radiator is bad about stopping up ..... I have to replace mine every 60 to 80,000, but if you have a NEW radiator, the most likely suspect is a sticking thermostat.
It is cheap, so get a brand name or go to the dealer and try that.
I know it has been a month, but the first time mine acted up it took me a month to find the problem.
Old Oct 2, 2017 | 06:54 PM
  #26
stimpy's Avatar
I find from working on them you have to buy a stant or Gm thermostat ( from dealer or ACD parts and they are not expensive ) the cheap ones tend to fail either it sticks with the bypass to the pump open and overcools or not opens to the radiator enough and the bypass is open which makes it run hot . also check between the a/c condensor and radiator for trash and you should also blow the condensor clear from the backside as they plug up too and limit the air flow if you have one .
Old Oct 2, 2017 | 07:29 PM
  #27
darkirish63's Avatar
If you didn't get all of the air out of the cooling system then you're going to get intermittent over heating. There are several writeups on refilling the system after all the changes you've made. I had the same issue when I swapped in the bigger radiator and e-fans until I took my time and filled the system up correctly. Never an issue after that.
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
BlownHD
Oct 3, 2015 12:24 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Shotguntommy
Sep 15, 2015 05:24 AM
