Outside temp in rearview converted to IAT??
Old Feb 9, 2004 | 10:08 AM
Scream's Avatar
MOOBIES Moderator
Default Outside temp in rearview converted to IAT??
Can you tap the intake tube to accept the outside temp sensor and display the IAT's instead of the outside air temps? Friend of mine suggested this and thought I'd get some opinions. Would it work? He's going FI so I'm sure that intake temps are going to be important to him.
I don't have the mirror, but have thought about getting it and this would be a pretty cool mod IMO.
Old Feb 9, 2004 | 12:12 PM
Scream's Avatar
MOOBIES Moderator
Anyone even know where the sensor is located?
Old Feb 9, 2004 | 12:53 PM
1LEThumper's Avatar
you should see it right behind the grill mounted to one of the supports
Old Feb 9, 2004 | 01:11 PM
Flyer's Avatar
You might could splice the wires in the MAF to with the wires from the temp sensor. I think they are black and brown in the maf. Unless he's going with the RADIX, it will only give him the temps the MAF sees, usually not the hot side, so it wouldn't be worth it much.
Old Feb 9, 2004 | 04:11 PM
marc_w's Avatar
I *REALLY* like this idea...
I had to pull my front end this weekend, and found the outside sensor under the passenger turn signal light.
It'd be quite easy to just relocated the sensor to the intake tube, as an additional one. They even sell the temp-sensitive-resistor down at radio shack for a couple of bucks... if you wanted to go that way...
In my '04, the IAT is in the MAF.
Old Feb 9, 2004 | 05:45 PM
L-EATER's Avatar
11 Second Truck Club
I have a IAT sensor mounted in the blockoff plug where egr would go if the truck had egr. I cut the wires from the MAF and ran them over to the new sensor. I never thought about using the mirror to monitor it, though-sounds interesting.
Old Feb 9, 2004 | 10:44 PM
Black Blown 02's Avatar
It seems like the mirror one wouldn't update fast enough to be useful with FI.
Old Feb 9, 2004 | 11:07 PM
bigguy75inches's Avatar
Im really interested in this too...i wonder if i could buy a second senser, and use a switch to go back and forth
Old Feb 10, 2004 | 08:32 AM
marc_w's Avatar
The mirror sensor uses the same resistor piece as the IAT does... you could always strip it out and make a custom mount for it in the intake?
Old Feb 10, 2004 | 09:49 AM
If that is it, then what is the wire that is center mounted, nearly, to the bracket just in front of the condenser, just behind the grill?
