Ouch!?
Old May 12, 2002 | 12:57 AM
truck's Avatar
Default Ouch!?
I have noticed that the 5.3 has a smaller bore size that the 5.7. I was wondering if I install the LS6 heads on my 5.3 will the valves hit the block or score the side of the cylinder wall? The heads will also be decked 0.0015. Help!!!
Old May 12, 2002 | 09:45 AM
GREGGO's Avatar
Default Re: Ouch!?
I would think after you deck them, it sould be pretty close. Regardless, I don't see how the valves will hit. Why are you doing LS6 heads? If your swaping stock for stock, I wouldn't expect anything to jump out and grab you (I'm no expert on that though). Personally, I would get a set of 6.0 heads with a mild P/P and go that route. Maybe a set of 4.8/5.3 stage 2's with 2.02/1.57 valves would be nice to. That's what I'm planning anyway (because I already have them). Good luck, when are you planning on doing it? Do a before and after dyno if you can. I'd like to see the #'s.
Old May 12, 2002 | 11:18 AM
GREGGO's Avatar
Default Re: Ouch!?
https://ls1tech.com/ubb/cgi-bin/ulti...c;f=1;t=004938
Here is a thread that has some good info.
Old May 12, 2002 | 01:01 PM
truck's Avatar
Default Re: Ouch!?
Thank you for the replies. I am doing the LS6 heads because I bought them for $200. I am planing on doing this swap in about a month a month and a half.
Old May 13, 2002 | 12:11 AM
oxidizr's Avatar
Moderator / Sponsor
Default Re: Ouch!?
The bores on the 5.3, 5.7 and 6.0 are all different. PTV (piston to valve) clearance should not be a issue even with decking due to the 5.3L's dished piston.
The only head where bore size seems to be and issue is the 6.0 to 5.3 swap. This leaves a fairly sizeable step between the top of the bore and the CC in the head. This is less appearant in the 6.0 to 5.7 or 5.3 to 5.7.
Richard
EVILGMC
Jun 16, 2009 05:06 PM
truckmann
Aug 14, 2008 01:22 PM
duwem
Aug 2, 2007 01:07 PM
Todd@AZPowerAndSound
Aug 16, 2004 02:24 PM
Nine Ball
Mar 20, 2002 10:55 AM
