Ouch!?
I have noticed that the 5.3 has a smaller bore size that the 5.7. I was wondering if I install the LS6 heads on my 5.3 will the valves hit the block or score the side of the cylinder wall? The heads will also be decked 0.0015. Help!!!
I would think after you deck them, it sould be pretty close. Regardless, I don't see how the valves will hit. Why are you doing LS6 heads? If your swaping stock for stock, I wouldn't expect anything to jump out and grab you (I'm no expert on that though). Personally, I would get a set of 6.0 heads with a mild P/P and go that route. Maybe a set of 4.8/5.3 stage 2's with 2.02/1.57 valves would be nice to. That's what I'm planning anyway (because I already have them). Good luck, when are you planning on doing it? Do a before and after dyno if you can. I'd like to see the #'s.
The bores on the 5.3, 5.7 and 6.0 are all different. PTV (piston to valve) clearance should not be a issue even with decking due to the 5.3L's dished piston.
The only head where bore size seems to be and issue is the 6.0 to 5.3 swap. This leaves a fairly sizeable step between the top of the bore and the CC in the head. This is less appearant in the 6.0 to 5.7 or 5.3 to 5.7.
Richard
Richard
Todd@AZPowerAndSound
Aug 16, 2004 02:24 PM
Nine Ball
Mar 20, 2002 10:55 AM
