The Other Guys Header GP
Old Jan 16, 2004 | 10:40 AM
tbyrne's Avatar
Default The Other Guys Header GP
You'll enjoy increased performance and fuel economy secure in the knowledge that The Other Guys mid-length headers are manufactured to the industrys highest standards. There are no compromises in material and workmanship.
14-gauge mild steel
Electroless-nickel-plated
Titanium-thermal-barrier-ceramic
Corrosion and heat resistant
1/2thick precision-cut flanges
50-state legal
Gain of up to 43 horsepower
California Air Resources Board (CARB) Exemption No. D-509
Exhaust flanges are made from beefy 1/2" thick steel plate (50100% thicker than most others) and ground flat.
Thick 14-gauge tubing is used instead of ordinary 16 or 18-gauge. Tubes are precision TIG welded to the flange.
A.I.R. refers to factory installed air pump emissions systems.
15 or more orders are required by Monday, February 2nd for the following GP pricing -
600222H 2001-'04 6.0 Chevrolet/GMC Heavy duty and H2 (3" Headpipes) $599.99
600222HC 2001-'03 6.0 Chevrolet/GMC Heavy duty and H2 (3" Headpipes) (A.I.R.) $599.99
580022 1999-'04 4.8, 5.3 Silverado, Sierra, Suburban, Yukon, Avalanche $599.99
580022C 1999-'04 4.8, 5.3 Silverado, Sierra, Suburban, Yukon (A.I.R.) $599.99
600222 1999-'04 6.0 Silverado, Sierra, Suburban, Yukon, Escalade with 6.0 Liter $599.99
600222C 1999-'04 6.0 Silverado, Sierra, Suburban, Yukon with Escalade 6.0 Liter (A.I.R.) $599.99
600222HD 1999-'04 6.0 HD Series 2500/3500 Chevy/GMC Trucks $599.99
600222HDCC 1999-'04 6.0 HD Series 2500/3500 Chevy/GMC Trucks (A.I.R.) $599.99
TOGCC Optional ceramic coating $150.00 - 4.8, 5.3 and 6.0. This coating is standard on the 8.1 header.
498025 2001-'04 8.1 Suburban, Avalanche 2500, 1 Ton Chevy/GMC Trucks (Reg. Trans.) $759.99
498025C 2001-'04 8.1 Suburban, Avalanche 2500, 1 Ton Chevy/GMC Trucks (Reg. Trans.) (A.I.R.) $759.99
498025HD 2001-'04 8.1 HD Series 2500/3500 Chevy/GMC Trucks Allison Trans. $759.99
498025HDC 2001-'04 8.1 HD Series 2500/3500 Chevy/GMC Trucks (A.I.R.) Allison Trans. $759.99
IMPORTANT INFO: Most products to fill each GP are ordered at the end of the GP. They usually take 1-2 weeks to ship from here, but some items could take longer based on the size of the group purchase and availability with the manufacturer. Depending on the product and our available stock, some orders will be shipped from here shortly after the GP comes to a close. Remember, you need to place your order if you are interested in taking part in a GP. Be sure to check the status of the GP that you are part of on it's closing date to see if is going through.
MORE IMPORTANT INFO: All credit cards are processed a few days before the GP closes to insure everything will go through without a problem and to lock in the order. Orders canceled after your GP order has been processed will be subject to a 10% processing fee. Orders for products that are non-stock items (not normally kept in stock) can not be canceled so be sure that you would like to be part of the GP before you place your order.
WHEN SHOULD YOU PLACE YOUR ORDER?: We find that alot of people wait for the required number of orders to be placed before they get in on the GP. If everyone does this the GP minimum is never met. If you would definitely like to join one of the group purchases that are listed it will be best to place your order as soon as possible. Your credit card won't be charged until just before the GP comes to a close (as long as there are enough orders) and the minimum will be met much sooner. This will allow you and the other participants to take advantage of the savings.
Orders can be placed online or by calling 1-877-4-TBYRNE. Just note the GP price when you place your order.
Have a good day,
Tom
Old Jan 16, 2004 | 10:56 AM
Flyer's Avatar
"WHEN SHOULD YOU PLACE YOUR ORDER?: We find that alot of people wait for the required number of orders to be placed before they get in on the GP. If everyone does this the GP minimum is never met. If you would definitely like to join one of the group purchases that are listed it will be best to place your order as soon as possible. Your credit card won't be charged until just before the GP comes to a close (as long as there are enough orders) and the minimum will be met much sooner. This will allow you and the other participants to take advantage of the savings."
This is so true .... step up or loose out in other words. I'd like to add, be sure and get these things coated, if not when you purchase them, before you put them on your truck. Your gas mileage will thank you and you won't get the dreaded SES light for o2 heater circuits. It'll also make them even better!
Old Jan 16, 2004 | 12:50 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
I'm in.
Hey Tbyrne, I only want in if the minimum number to get the price is met. If the minimum number needed is NOT met, will my credit card still be charged?
Also, I don't remember what the "A.I.R." thing means. I don't think I have it but the TOG's would be for my '01 4.8 Sierra. I would also like them coated.
Old Jan 16, 2004 | 02:46 PM
tbyrne's Avatar
This is currect. Your card won't be charged unless the minimum is met.
Header terms you should know when ordering -
Air injection: If you’re vehicle has an air injection system connected to the factory manifolds, you will see metal tube(s) that attaches to the manifold with a metal fitting. You may have one on each side. Note the quantity and location as they may be different between vehicles.
Port Air injection: This system is common on many GM and Ford Trucks with V-8 engines. If your vehicle is equipped with this system you will see metal tubes connecting to each exhaust port on the factory headers.
EGR: Exhaust Gas Return systems are common on many vehicles. If your vehicle is equipped you will see a metal tube that is connected to one of your exhaust manifolds and usually goes to the induction system or cylinder head.
Hope this helps,
Tom
Old Jan 17, 2004 | 09:06 PM
04sierra's Avatar
I would like to get in on this. As you can see I am brand new to the forum. How can I be involved in the group purchase? Can I get them ceramic coated?
Old Jan 18, 2004 | 02:12 AM
Flyer's Avatar
Go to Tom's site, www.tbyrne.com and go to the Group Purchase section and sign up there. You can also email or call him.
Old Jan 18, 2004 | 12:02 PM
tbyrne's Avatar
You can place your order on the website or by calling 1-877-TBYRNE. Alot of people still order at the regular price so be sure to mention that you would like to take part in the GP. The ceramic coating will add $150. to the headers.
Tom
Old Jan 20, 2004 | 11:48 PM
Just placed an order. Hope this thing goes through.
Old Jan 21, 2004 | 07:53 AM
onyx's Avatar
14 Second Truck Club
i'm still debating on jumping in on this.. consider me half-way.
Old Jan 21, 2004 | 07:59 AM
tbyrne's Avatar
There are 5 orders in as of this morning. We just need 10 more by the 2nd for this to be a go!
