Ordered A Nelson 93 Tune
Old May 26, 2004 | 03:46 PM
therock's Avatar
Default Ordered A Nelson 93 Tune
I'll be reporting a comparison to the Predator I run now and will elaborate on gas mileage in detail as well. I don't see anything like that so I'll post my findings there.
I also will be reporting on his PCM electric fan control harness. I like the idea of the PCM knowing exactly what the coolant temp is. I have Flex-a-Lite 292s'. There are no variable speeds, it runs 1 fan full speed when needed and the other when the AC Comp clutches in.
I have a 2003 Z71 Silverado Extended Cab - 5.3, Locking 3.73 gears, E-fans, K&N in OE box, and a SS Silverado cat back, true duals in and the big single out.
I should be reporting my first impressions by mid next week. The MPG report will follow about 2 weeks after.
Old May 26, 2004 | 03:49 PM
due a home brew intake, that should help some and is pretty cheap. I would like to here this info.
Old May 26, 2004 | 07:26 PM
SimpleManLance's Avatar
what is this harness you are talking about. how did you wire your fans into the truck and get it controlled off the pcm. i am very interested!!!
Old May 26, 2004 | 07:59 PM
what was the cost for the harness?
Old May 27, 2004 | 04:15 AM
therock's Avatar
Default Nelson's Fan Harness
Cost - $59.00. I havn't received it yet but it ties in the pcm harness in an available pin socket if I heard him right. Next week I'll have pics.
Old May 27, 2004 | 09:23 AM
did you buy it from nelson?
Old May 27, 2004 | 01:55 PM
O3GMC's Avatar
12 Second Club
You will like it better than the Predator, I do
Old May 27, 2004 | 02:00 PM
therock's Avatar
Default Yes
He says through testing in hot climates one fan is plenty without the AC compressor running.
We will see.
Old May 27, 2004 | 07:04 PM
Whistlin00's Avatar
14 Second Truck Club
You'll love the tune. Its the best thing I've done to my truck.
Old May 28, 2004 | 05:27 PM
04BlackSilverado's Avatar
You got the Nelson 93 Tune ?
do you know the dyno for that?
My truck is stock and she hasent seen below 93 yet and I want to put it to use
P.S. can you see my pic in my Signature?
