optimal bearing clearance...
Old Feb 26, 2008 | 02:20 PM
lt1s10's Avatar
Default optimal bearing clearance...
What are all the high hp guys running for main, rod and ptw clearances???
Old Feb 29, 2008 | 10:12 PM
negativeswitches's Avatar
as far as i know you should want factory rod and main clearances and then ask you piston supplier what they reccomend for a PTW clearence also reference in about .003 if you are going to spray a big shot of the juice
Old Mar 2, 2008 | 01:41 PM
ncperformance's Avatar
Rods .0018 to .0025
Mains .0020 to .0027
stay on the tight side if you use nitrous to keep from beating the bearings to death and use a good oil
no less than .005 on the thrust
ptw depends on the piston material/skirt length - whether the block is iron or aluminum - types of power adders etc. - anywhere from .002 for a cast piston to .005 for a forged nitrous application (actually seen applications with as much as .009)
Call our engine builder and S.A.M. graduate Heath Clayton if you've got anymore questions.
217-676-2660
New Covenant Performance Inc.
GMCtrk
Jan 27, 2016 06:47 PM
carid
Oct 28, 2015 08:24 AM
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 04:22 PM
600 horses
Sep 10, 2015 11:01 AM
