opinions: STS vs RADIX
Old Sep 16, 2004 | 01:24 AM
  #211
moregrip's Avatar
what a rush!
Originally Posted by rgcbshrty
Something to consider in regards to off idle boost. While idleing the quantity of air flow entering the screw compressor will be of such a minute quantity there probably won't be much of any heat build up issues. With that scenario there just won't be much air to compress, especially when the bypass valve is factored in. Then there is air delivery and the distance it has to travel. The roots paddles the air around the outside of the rotors, while the screw sends it down the middle. Each, if they are the same displacement, will deliver the same quantity of air with each revolution of the rotors. What I would like to know is if each would require the same number of rotor revolutions to build like boost. I would assume the screw would have an easier time of building boost due to actually compressing the air.
a twin-screws worst enemy is any off boost condition, that includes idle.
Old Sep 16, 2004 | 01:30 AM
  #212
Mr. Sandog's Avatar
I'd really like to get behind the wheel (actually I'd even settle for a passenger-seat view) of a twin-screw machine and make that judgement for myself. Maybe I'll go to the next Dyno Day in Santee and coax one of those Cobra guys into giving me a ride in his Kenne Bell powered machine. There are always 2 or 3 of them at each event.
I think the next one's on Nov 13th.
Old Sep 16, 2004 | 01:33 AM
  #213
moregrip's Avatar
what a rush!
Originally Posted by Naked AV
I'd really like to get behind the wheel (actually I'd even settle for a passenger-seat view) of a twin-screw machine and make that judgement for myself. Maybe I'll go to the next Dyno Day in Santee and coax one of those Cobra guys into giving me a ride in his Kenne Bell powered machines. There are always 2 or 3 of them at each event.
I'd like to as well, Maybe I'll dyno my truck for my 33rd Birthday
Old Sep 16, 2004 | 01:43 AM
  #214
rgcbshrty's Avatar
The best answer would come straight from Autorotor/Lysholm, Eaton, KB Magnuson, Whipple. It may take a few calls, but I've been able to speak with techs from each company in the past, except Lysholm. If you call early enough you can speak with a tech at KB, possibly even Jim Bell. Autorotor has a US division, so calling europe won't be necessary.
Even then you'll more than likely get conflicting answers. I'm curious as to what each would say about their product.
Old Sep 16, 2004 | 01:44 AM
  #215
Mr. Sandog's Avatar
Actually, I think the best answer would come from the SOMP.
  #216
moregrip's Avatar
what a rush!
are you on assignment?
Old Sep 16, 2004 | 02:39 AM
  #217
rgcbshrty's Avatar
I may be if I decide to switch my eaton for a KB. Although at high boost levels I doubt it would make difference. Check out www.nloc.net. That would be a good topic to post over there.
Yes
Old Sep 18, 2004 | 03:01 AM
  #218
moregrip's Avatar
what a rush!
MM&FF did an article on the Eaton vs. Autorotor in the April issue. The KB has the ability to produce much greater boost levels, but running at lower boost levels (8 PSI or so) the Eaton produces slightly more at low revs.
Old Sep 18, 2004 | 04:46 PM
  #219
rgcbshrty's Avatar
That was an imformative article. I would definately keep my Eaton if I were to stay at or slightly above stock L boost levels.
Old Sep 18, 2004 | 04:51 PM
  #220
moregrip's Avatar
what a rush!
The Radix is good for 13psi on some applications.
