opinions: STS vs RADIX
Old Sep 9, 2004 | 09:44 PM
  #101
moregrip's Avatar
what a rush!
OK, that's my case.
Any takers?
Old Sep 9, 2004 | 10:14 PM
  #102
Flyer's Avatar
Interesting. That's a really good read on the RADIX. Where did you egt that from, I'd like to see the pictures too.
  #103
Yep....do you have one?
Old Sep 9, 2004 | 10:17 PM
  #104
moregrip's Avatar
what a rush!
which read? I'll post the link no problem.
Old Sep 9, 2004 | 10:23 PM
  #105
zippy's Avatar
damn more grip, you like to type.
Old Sep 9, 2004 | 10:45 PM
  #106
moregrip's Avatar
what a rush!
oh I can copy and paste with the best of them
Old Sep 9, 2004 | 11:12 PM
  #107
Flyer's Avatar
The first one mainl, but both links would do.
Old Sep 9, 2004 | 11:25 PM
  #108
moregrip's Avatar
what a rush!
http://www.tomhenryracing.com/technical/default.htm
Old Sep 10, 2004 | 12:30 AM
  #109
MacADaYear's Avatar
Cliff notes would be great
Old Sep 10, 2004 | 01:24 AM
  #110
rgcbshrty's Avatar
Originally Posted by BenKey
I would disagree with that some. The boost number I always give out that I attained with the Radix (10.3psi) was only ever hit just before the shift. That was shifting at 6200 and sometimes 6300. Didn't always peak in the 2-3 shift, but for sure on the 1-2. It did this in every cam I put in my truck, from small to big. Don't get me wrong, I would hit about 8.5-9psi at about 3000-3500rpms, but to hit peak was seconds later. Never could you do a 7psi launch, and not so sure if you can get it to give 1lb prior to launch. I never could, but honestly didn't try it too often.
Boost "seen" is dependant on the volumetric efficiency of an engine. The reading on a boost gauge will never constantly read what the blower is pulleyed for. Boost is a measurement of back pressure. It can be misleading when manufacturers state full boost at any rpm. One assumes a 5psi pulley will show, on a boost gauge, 5psi at any rpm. Once you're wot a positive displacement blower will deliver its "full volume of air"(aka full boost), whatever volume the pulley is sized to deliver. Although due to the flow characteristics of an engine, boost readings may rise or fall as rpms increase. The Lightning is set for 8psi from the factory yet can yeild a few more psi up top with just air box mods. Apparently, with the Cobra boost readings drop off up top.
