Opinions on 370 build
Old Oct 19, 2015 | 07:09 AM
DAH32's Avatar
That is correct. This is a very mild build. Maybe just a tad over stock.
Thanks for the help. Please keep the suggestions coming if anyone else has something to say.
Old Oct 29, 2015 | 12:45 AM
JoeyGC5's Avatar
Im very happy with my Isky cams spec'd by Jarrod (Stock48). My mud truck 4.8 uses his 212/216, my turbo trucks 5.3 uses the triple 12, and my 370 twin turbo Vette runs his 219/222
Old Oct 29, 2015 | 02:59 AM
gamble686's Avatar
You should probably consider a custom cam. It's a very odd set of desires you have for your build. I also agree that you should be spinning it to 6k on a full wot run. That doesn't mean you need to see anything more than 5k on a regular basis, but having the best part of the power band is a good idea. Anyways sticking with factory cathedral heads and wanting power early I would suggest something like a 215/223 low lift LSA 113+2
It will have a broad early power band.
Old Oct 30, 2015 | 09:10 AM
DAH32's Avatar
Its not the normal you build you see here. It is just a small step up from a stock rebuild. No track time, drag strip. The truck is alot of fun on twisty roads though. Handles very well. The truck is a daily driver. Thanks for your recommend. That is about what Im seeing. Seems like alot of the recommends are around that and just a touch larger. Not looking for much. If I was to get 375 horsepower at the flywheel on 87 octane that would fit the bill.
thundurchasur
Oct 6, 2015 10:01 AM
Wolftrk99
Oct 2, 2015 08:17 AM
Slammed silverado
Sep 28, 2015 06:14 PM
Raiderjim
14
Sep 26, 2015 10:18 PM
