Opinions on 370 build
Old Oct 17, 2015 | 09:09 AM
DAH32's Avatar
Default Opinions on 370 build
Anyone want to throw out some cam specs for a solid street 370 build?
I figure around 10 to 1 compression with 317 heads and long tube headers. Nothing all that much. Just strong from idle to around 5200 or so.
I was thinking around 210 @ .050 with .530 to .550 lift. Not sure.
Want to keep the engine on 87 octane.
Old Oct 17, 2015 | 12:29 PM
madmann26's Avatar
I've got a 218/224 @ .551/.551 114 lsa in my .040 over 6.0l.
It's plenty strong for me.
Old Oct 17, 2015 | 01:47 PM
FFDP's Avatar
I don't think 87 will cut it.
Old Oct 17, 2015 | 02:29 PM
DAH32's Avatar
What kind of rpm band does it have?
Old Oct 18, 2015 | 03:35 PM
madmann26's Avatar
It starts pulling REAL hard around 3k but I don't lock my converter until 4th @ 52mph.
Old Oct 18, 2015 | 06:25 PM
USMCvet0311's Avatar
My setup is in my sig. Tooley said it should be a solid setup on motor before the 200 shot. Hope this helps.
Old Oct 18, 2015 | 10:12 PM
Vortec350ss's Avatar
The LS heads are so good in stock form that you really want to rev it beyond 5200 RPM. As mentioned before you are not dealing with a standard small block chevy here...
Hell a tuned stock cam will often be revved to about 6k. If it were mine and it was a true torque build I would be looking at at least 6k RPM shift points.
216/220 112+3 with 550 lift. Id use GMPP LS9 springs.
Old Oct 18, 2015 | 10:14 PM
DAH32's Avatar
I dont need any of that. Im not trying to out run stuff.
I already have .030 pistons that will give 10 to 1.
I just need to get cam that do what I want. Run the fuel that I want. I can try and get a tight quench and the right head gasket to bleed off the pressure and run 87 octane.
Thats all I need.
Old Oct 18, 2015 | 10:18 PM
I'd recommend a BTR truck cam..... Stage 1 or 2 if you're keeping it mild.
Old Oct 18, 2015 | 10:21 PM
This cam will give you what you want. My 222/226 on a 114 gave me a better 60' than my stock cam. Yours will only improve bottom end power even more...
