Opinion on used camshaft?
Old Oct 16, 2007 | 10:10 AM
KY_BOB's Avatar
Default Opinion on used camshaft?
I know that I grew up in the old school days for flat tappet cams but on those motors, I would never use a camshaft from another engine. Of course they were cheap and even if you did, you had to replace the lifters.
I know that roller lifters do not wear themselves or camshafts like the old flat tappets and that they don't have to be replaced when doing a cam swap.
All of that said:
Is it 100% safe to buy and install a good low mile cam?
I've found a suitable cam and am just looking for some reassurance that it's OK to save $100 or so by going this way rather than buying a new one.
Old Oct 16, 2007 | 10:12 AM
99/5.3w/hips's Avatar
perfectly safe. Pick it up and get it in there
Old Oct 16, 2007 | 10:14 AM
silver-mod-o's Avatar
Hunt&Fisherator
how many miles?? I'd still thoroughly inspect it and/or have it polished before it goes in...
Old Oct 16, 2007 | 10:18 AM
KY_BOB's Avatar
2300 miles. I found it online, so I can't inspect it personally. The guy assures me that there are no noticeable wear marks or visible scratches.
Old Oct 16, 2007 | 10:19 AM
Quik's Avatar
5 year bitches!
dont worry about it, get it and install it. and anything you know of old school just throw out the window.
Old Oct 16, 2007 | 10:21 AM
Hunt&Fisherator
you're in good shape then, slide 'er on in...
Old Oct 16, 2007 | 10:22 AM
Quik's Avatar
5 year bitches!
lube it first, if you just try and slide it in without lubing your shaft, your have failure
Old Oct 16, 2007 | 10:26 AM
RandomHero's Avatar
Or extreme uncomfort at least
Old Oct 16, 2007 | 10:27 AM
Hunt&Fisherator
might just take a little more work
Old Oct 16, 2007 | 10:28 AM
Quik's Avatar
5 year bitches!
is that what your block told ya
