Which Oil pump O-ring???
Old Dec 10, 2017 | 05:17 AM
Camin00's Avatar
Default Which Oil pump O-ring???
Sorry for old school question.... but read several sources and they say different colors and sizes.
Truck is 2000 LM7 stock 200K mile oil pump.
Pressure has been down a little around 30-35psi last month or two, was always 40-45 until last month or two. So hoping changing O ring will fix it, as it is way easier of a job verse swaping pump for new one.
Hell if I have to swap pump might as well put a larger cam in, but I really don't want to do that or spend the time/money.
Old Dec 10, 2017 | 12:23 PM
madmann26's Avatar
Have you tried a heavier oil? With 200k I'm betting the clearances are a little looser.
As for the oring...get one of each color. They're cheap enough.
Hell, I've got an extra one I can send along with some water pump gaskets. Free just send me a PM with your address.
If you do a cam...now is a good time to replace the pump and do a new timing chain with the newer dampers.
I would highly suggest having the proper tools. I've been stockpiling tools for the last few months. I got a very good pulley puller that I got to use Friday and I'll tell you what, it made getting that crank pulley off a breeze.
I also have the pulley install tool as well. You can also use a ls7 crank bolt to get the pulley back on.
Get 2 5/16 wooden dowel rods to hold the lifters up. Cut them to 22in.
Old Dec 21, 2017 | 05:25 PM
RedXray's Avatar
100% Redneck
If using an OEM or Melling o-ring just decipher the chart.
Ferocity02
Mar 11, 2010 10:36 PM
xdanny510x
Jan 15, 2008 06:15 PM
Last Call
Mar 5, 2006 07:21 PM
99Silver6.0
Apr 16, 2004 05:25 PM
