oil pump already?
Had my cam swapped about 5 days ago and everything has been fine until last night. I went to crank up my truck and the check oil pressure light come on. I immediately shut it back off. I checked for leaks, made sure the truck had oil in it (it did) and everything was ok. I waited a few minutes and then turned the truck key on and off several times and started it again and immediately shut it back off, still the same thing. NO OIL PRESSURE. The thing is, the guy didnt even touch the oil pump and my truck rolled over 36,000 miles last wednesday. Is this a problem with these trucks (2002) or what? Do you think I messed anything up so far?
If your getting this message does the oil pressure gauge value agree or does it show that you are actually making pressure. Since the pump is mounted directly on the crank the chances that you really have "0" pressure if you didn't touch the pump or pickup tube and you have done your oil changes regularly are quite remote. Because the LS1 oil pump is crank driven instead of cam driven you should make a lot of oil pressure even at idle, but you are doing the right thing in turning the key off IMMEDIATELY if there is any doubt if you have sufficient pressure or not. I installed one of those LS6 ported and blueprinted pump and it gives 50lb at idle and more that 70 lbs at highway speeds.
Yes, the message center agrees with the oil pressure value "0". I change the oil via the message center and have run mobil 1 5w30 synthetic since the first oil change. It is just odd that It gave no signs or anything. the oil pressure usually reads about 50at idle and around around 70 or so when I get on it. About the same as the ported one. Hell, I thought since I wasnt having any problems with it, I should leave it alone and now this.
Ah dude! That frikkin sucks!! **** I hope I dont run into any problems after I do my cam, oil pump and stuff. Is there any way to avoid a problem like this happening after a cam install?
OK, here it is courtsey of Getsome. I knew it was something with the pickup tube. The exact culprit ended up being an O-ring. Also may want to check out the over pressure relief valve. Hope this helps!
https://ls1tech.com/forums/showthrea...t=Oil+Pressure
Originally Posted by BenKey
If it's an issue with the pick-up tube o-ring, then I would find it hard to believe that the the oil pump was not messed with. Did you watch the guy do it?
pupi305
Sep 14, 2015 11:40 AM
Ferocity02
Jul 17, 2015 07:05 PM
