Oil pressure? O ring?
Old May 3, 2008 | 03:39 AM
CashDudeHomie's Avatar
Default Oil pressure? O ring?
My oil pressure seems to be lower than it used to be. It's about 35 at idle and a like 55 at WOT. I think it used to go higher than that.
I had to remove the oil pickup tube last weekend. I don't remember seeing an O ring though. It was just a big rubber seal. This is a 2003. Did they do away with the O ring for the bigger rubber seal? Does my pressure sound ok?
I will probably replace the seal on my next day off because I broke an oil pan bolt anyway :bang but I want to see if it's safe to drive for now. Thanks, and yes I did a search.
Old May 3, 2008 | 08:12 AM
ramsey rider's Avatar
idk about a big rubber thing but theyre shoulda been an o ring.if you replace it get the red oring its better.mine sits at 35-40 at idle and its a 06 6.0.but i do shoot up to 80 at wot. it wouldnt hurt if u have the pan off.
Old May 3, 2008 | 09:48 AM
Tootall's Avatar
RED o-ring,
left 12563963 RIGHT 12584922
Old May 16, 2008 | 08:56 AM
Hey, thanks for the part #. I replaced my O ring this morning and now my pressure is back to normal. I replaced the other rod bolts as well while I was in there.
My old O ring was so deformed. It was more square than round. It didn't even look like an O ring.
Any guys who run into this on a search, replace the O ring every time if possible!! If it shows any signs of deformation, it won't seal as tight as it should. It's only like 7 bucks. You don't want to have to tear into it again if your pressure is lower than before.
Texas5.3_1251
Mar 5, 2016 08:10 PM
mikeyjm1
17
Oct 29, 2015 11:04 PM
OHsixLS3
Sep 25, 2015 11:20 AM
Brandonlflr12
Sep 8, 2015 09:01 PM
Boyes50
Sep 8, 2015 12:06 PM
