oil pressure
Old Mar 29, 2010 | 07:13 PM
05gmc's Avatar
Default oil pressure
ok i did a swap and hooked a manuel guage on the side of the oil pan were the filter is or the oil cooler lines go should i be geting a reading there when i start it it goes to about 20 and at ideal its on 0 do i need to find another spot for my guage
Old Mar 29, 2010 | 07:16 PM
00ChevyScott's Avatar
Wearin' da big hat
Are you adding an extra gauge or what? The factory oil pressure sensor goes on the rear of the motor right behind the intake manifold. What swap are you referring to?
Old Mar 29, 2010 | 07:34 PM
05gmc's Avatar
yes an extra guage is added i put a 6.0 in my 70 elcamino
Old Mar 31, 2010 | 03:28 AM
454SuperSport's Avatar
make sure that whatever you have bolted right there still allows the oil to flow between the two holes.
Old Mar 31, 2010 | 01:22 PM
SnakeOiler's Avatar
So, you have this actually in the pressure port adapter (above the oil filter)?
Picture of the installation? (pic says a thousand words!)
At what RPM are you reading 0psi?
Are you positive all gauge connections are correctly hooked up?
Texas5.3_1251
Mar 5, 2016 08:10 PM
69z-28
Sep 21, 2015 07:31 AM
Go5.3tt06
Sep 14, 2015 02:11 PM
Brandonlflr12
Sep 8, 2015 09:01 PM
Boyes50
Sep 8, 2015 12:06 PM
