oil pressure
Old Oct 4, 2009 | 05:45 PM
05gmc's Avatar
Default oil pressure
ok 2000 4.8 when i start the truck 0 oil pressure and lifters srart taping if i give it gas the oil pressure goes to 50 and the tapping stops can anyone help
Old Oct 4, 2009 | 06:54 PM
texasbullseye89's Avatar
what wight oil are you using?
Old Oct 4, 2009 | 09:56 PM
05gmc's Avatar
20w50
Old Oct 4, 2009 | 10:05 PM
stock motor? There a reason you're using something that thick? GM recommends 5-30 year round. That stuff is like glue trying to work its way up to the top... hence the ticking, oil isn't getting to the lifters.
Old Oct 5, 2009 | 10:17 AM
Mort's Avatar
Are you running the proper oil filter with an anti-drain back valve?
I agree, that oil is thicker than you need.
Old Oct 5, 2009 | 11:45 AM
MikeGyver's Avatar
20w50?! This is a modern, high-tech engine in your truck, not an AMF era Harley. Put 5W-30 in there, your gas mileage will improve, too.
Texas5.3_1251
Mar 5, 2016 08:10 PM
69z-28
Sep 21, 2015 07:31 AM
Go5.3tt06
Sep 14, 2015 02:11 PM
Brandonlflr12
Sep 8, 2015 09:01 PM
Boyes50
Sep 8, 2015 12:06 PM
