oil Pressure
Old Nov 16, 2007 | 11:26 AM
Tyler's Touch's Avatar
Default oil Pressure
What is your oil pressure registering at on your cluster? Mines at idle 35-but never seems to go past 60 even redlined. Apparently ive got the other filter from ACDelco PF46 vs. 42 or the other way around (ive got the larger filter) Is this normal?
Old Nov 16, 2007 | 11:32 AM
CHEVRACER83's Avatar
What Oil Are You Using???
Mine Will Just About Peg 80 Psi At Redline... But My Motor May Be A Little Fresher Than Yours... Not To Mention If Your Using A Lightweight Oil You Can Sacrifice Some Pressure.
It Will Peg 80 Easily When Cold... But Once Warm It Will Pretty Much Hit 80
Old Nov 16, 2007 | 11:51 AM
Ive got Mobil-not synthetic 5W30-its about 48* outside...even when the trucks cold the pressures under 60
Old Nov 16, 2007 | 12:03 PM
thunder550's Avatar
High on diesel fumes
Yours sounds like it's probably ok, as long as pressure increases with RPM I think you're fine.
Old Nov 16, 2007 | 01:12 PM
+1 MOST IMPORTANT THING IS YOU HAVE I BELIEVE ABOUT 7PSI PER 1K RPM... THAT WAS A BASELINE I LEARNED FROM AN ENGINE BUILDER I USED TO WORK WITH
Old Nov 16, 2007 | 02:50 PM
budhayes3's Avatar
PT's Slowest Truck
Seems like different trucks see between 30ish to 40ish at idle with the factory gauge, and anywhere from 60 to pegged at 80 WOT. My oil pressure is just above 40 at idle (650rpm), and will peg the needle at 80 WOT. I used to use Mobil1 10w-30 and an ACDelco PF-59 filter, but just switched to Amsoil 5w-30 and a Mobil1 oil filter when I did my last LOF. The oil pressure (according to the factory gauge pretty much stayed the same either way).
Old Nov 16, 2007 | 03:43 PM
Nothing ever seems right in my truck lol
Old Nov 16, 2007 | 03:55 PM
xsports33's Avatar
Once i'm warmed up i idle around 36-37. WOT i can peg it at 80 as well. Mobil1 5w-30 with the PF46 filter
Old Nov 16, 2007 | 04:06 PM
Cuerva's Avatar
11 Second Truck Club
Mine's above 40psi at idle and will peg 80 at WOT w/129k lol. My 04 tahoe used to run at around 32-37psi and would get close to 80 at WOT.
Old Nov 16, 2007 | 10:42 PM
sprayed8's Avatar
same here, wih 140K, K&N filter and royal perple, it never quite pegs even at WOT. yours sounds fine to me.
