Oil Pressure
Old Dec 9, 2004 | 07:52 PM
Default Oil Pressure
My oil pressure flucutates at idle. It fluctuates by about 5 psi.
Is this a sign that my oil pump is about to go out??
Old Dec 9, 2004 | 10:32 PM
04BlackGmc's Avatar
10 Second Club
At idle thats kinda weird maybe the sensor..
Old Dec 10, 2004 | 10:24 AM
ktmrider's Avatar
You can try to install a remote gauge first as the oil sensor is rather hard to get to ( back of the engine, needs special tool ).
My guess is sensor tho.
Old Dec 10, 2004 | 10:35 AM
Deckhand's Avatar
Are you cammed or anything?
Somtimes if your motor is surging a little, it will cause some movement.
Old Dec 10, 2004 | 10:54 AM
GREGGO's Avatar
5 psi is not that much. Are you running the A/C when you notice this, or does it do it with all the accesories off. What are your normal readings at highway and city speeds and where does it run between at idle....hot, cold etc....
Old Dec 10, 2004 | 02:56 PM
on my 95 camaro my headers were nice enough to melt the oil sending unit sensor or whatever it is and caused a problem like this but i think i remember it being a lot more than 5psi difference. im pretty sure it was all over the place. do the trucks have the same kind of unit????????
Old Dec 10, 2004 | 03:01 PM
Since my cam install mine fluctuates at idle too. I have always used 10/40 oil in it too, but now that i'm up in the cold i tried some 10/30 and it idles around 25-30psi. With 10/40 it idles at 40psi and fluctuates less.
Maybe bad oil?
Old Dec 10, 2004 | 06:55 PM
Mine moves a little. I dont think it moves 5psi, but it does move a little bit. It done it since i bought the truck brand new. I run Mobil 1 10/30.
Texas5.3_1251
Mar 5, 2016 08:10 PM
69z-28
Sep 21, 2015 07:31 AM
Go5.3tt06
Sep 14, 2015 02:11 PM
Brandonlflr12
Sep 8, 2015 09:01 PM
Boyes50
Sep 8, 2015 12:06 PM
