Oil pans
Old Jul 23, 2016 | 08:44 AM
druff's Avatar
Default Oil pans
Not really performance (sorry about that) but it's going on a performance engine.
When the old one exploded it put a dent in the tube that is molded into pan for the filter.
Guy I bought the engine from gave me another oil pan free, but it drains to the side and has these fittings on that 90 (picture included)
What is that fitting? My old pan is a rear drain without that little feature and it threw me for a curve
Old Jul 23, 2016 | 09:34 AM
Jake75's Avatar
I believe it is a built in pressure relief. Some people take it out and plug it to help increase oil pressure.
Old Jul 23, 2016 | 10:04 AM
FFDP's Avatar
Yeah, that's a gen 4 oil pan, they have that relief for the VVT/DoD systems. You can just remove it and plug the oil so it has a more normal oil pressure readings like a gen 3 motor.
Old Jul 23, 2016 | 10:14 AM
druff's Avatar
Alright so gen 4 pans are exactly the same as gen 3 except for that little relief fitting?
Old Jul 23, 2016 | 10:18 AM
FFDP's Avatar
Mostly, the drain spot is different and they did away with the oil level sensor too.
Old Jul 23, 2016 | 10:22 AM
druff's Avatar
Alright so I'm gonna get a code for not having that sensor correct?
Old Jul 25, 2016 | 11:11 PM
jakerps13's Avatar
No codes but may have the dash say low oil level and the chime going off.
The pans are slightly different. The gen3 is slightly deeper at about 8.5 inches at the front with a rear drain bolt. The gen4 is roughly 8 inches deep at the back with a passenger side drain plug.
Cowboy Tom
Jun 2, 2016 08:15 AM
B&M Racing
May 3, 2016 04:26 PM
B&M Racing
May 3, 2016 04:25 PM
dmc454
Apr 26, 2016 11:22 PM
53bowtie
Apr 26, 2016 01:15 PM
