oil catch can
Old Sep 15, 2010 | 01:53 PM
BlackGMC's Avatar
Resident Retard
These are the only pics i have... I will have some better pics this weekend when i install my TBSS intake...
Banned
I have a Mike Norris one on my Camaro. They are quality pieces.
Old Sep 15, 2010 | 02:08 PM
BlackGMC's Avatar
Resident Retard
I would highly suggest prior to installing one put a vacuum pump on the catch can and check it for leaks. Mine leakex like a ****, i had to reseal all the fittings. It took a little while to figure it out cause my trins went crazy due to the un-metered air being let in
Old Sep 15, 2010 | 02:56 PM
ezdaar's Avatar
You guys want a REAL Catchcan?
Instead of those over priced aluminum cans that amount to nuthing more than a empty expansion chamber?
Check this out.
http://www.saikoumichi.com/OCC_explanation.htm
I build mine, the exact same way out of PVC, brass barbs, brass tubing inside and stainless filter screens. Painted black or use black PVC.
I also put 2 90* barbs on one side of the can with a clear tube connecting them, this allows you to easily see when it needs to be drained and cleaned.
A properly setup can will reduce 99% of the blowby gasses from re-entering your Intake.
GL
Old Sep 15, 2010 | 03:38 PM
8.1 HD's Avatar
I run one from Elite Engineering.
Old Sep 15, 2010 | 03:45 PM
06Sierra2's Avatar
black gmc, since your truck is an 04 you ordered a c5? and if i order one of these i would choose a c6 since mine is a 2006? just not sure on the different year vettes compared to the trucks
Old Sep 15, 2010 | 03:49 PM
BlackGMC's Avatar
Resident Retard
I think the year on those is just for the mounting perhaps? I have no idea which year i ordered.. More than likely they are all exactly the same...
Old Sep 15, 2010 | 03:59 PM
06Sierra2's Avatar
yeah probably... ok thanks
Old Sep 16, 2010 | 05:27 PM
02'Z71ONDUBZ''s Avatar
Corey, that's actually a Mike Norris Motorsports catch can. They are quality pieces from all that I've read. Vengeance Racing sells them along with some other people. I think they are on Amazon under a different name. Also, I believe he is a site sponsor over on tech. Search over there, they have some good threads between it and the Rev Max which appear to be the two of choice. It's the can I'm gonna run on my setup.
http://www.mikenorrismotorsports.com...atch_Cans.html
Old Sep 17, 2010 | 12:03 AM
Spoolin's Avatar
GFYS and STFU
FlyingLow
Nov 24, 2015 10:05 AM
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 04:22 PM
lxcoupe
Sep 25, 2015 12:36 PM
97_ek
Sep 23, 2015 09:16 PM
