Oil
Old Dec 29, 2011 | 05:40 PM
Blake did it's Avatar
Default Oil
I have obviously been using oil somehow in someway..... I have no smoke, no drips, no spots on drive, oil pressure is always up..... yet I was almost a Q and a half low today??????
any ??
Old Dec 29, 2011 | 06:20 PM
PCV system, pull your air intake off and open the throtle body you will see where your oil is going.
Old Dec 29, 2011 | 08:56 PM
01silvy's Avatar
Yep i say PCV system too.. my truck use to burn about a qt every 1k, i changed the PCV valve and now it burns about 3/4 qt over 3,500 miles.. still burns it but its a heck of alot better.. You may want to look into a catch can or just completely getting rid of the PCV system.. i want to get rid of mine but im gonna wait until i do my 6.0 swap, and im still not 100% sure how to get rid of the PCV system and properly vent the block without causing any kindof unmetered air throwing off my tune or A/F ratio.
Old Dec 29, 2011 | 11:49 PM
06Sierra2's Avatar
agreed, the same thing happens to me as well. im going to run a catch can and see what happens.
Old Jan 8, 2012 | 03:48 PM
Thanks... I wouldn't mind doing away with it altogether since there are no emission standards where I am now. Wouldn't know where to start though, guess I will search it here and then see what I can come up with. catch can would be alot easier I guess... I'll change the valve itself first ....
Old Jan 8, 2012 | 06:36 PM
02'Z71ONDUBZ''s Avatar
pull the pcv hose off the top of the intake, cap of the nipple on the intake, and put a filter on the hose from the pcv. remove the line that goes from the passenger side valve cover to the throttle body, and cap off both. put a breather on your oil fill cap, your done. Or you could forget the breathers and run lines from the pcv and passenger side valve cover to a catch can, to the intake, with a cap on the throttle body nipple and no breather on the oil fill cap.
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 04:22 PM
lxcoupe
Sep 25, 2015 12:36 PM
69z-28
Sep 21, 2015 07:31 AM
Velocity1
Sep 15, 2015 11:29 PM
