Oil
Old Oct 4, 2006 | 08:32 PM
DamnYankee's Avatar
formerly Moze (2/24/2012)
I went with AMSOIL mainly because I can't find anyone that shows the results of similar tests. And they test against the name brands. I've posted all my thoughts here:
http://forum.ls1truck.com/index.php?showtopic=7983&st=0
Old Oct 4, 2006 | 08:37 PM
DamnYankee's Avatar
Originally Posted by gnd111
Oil is oil..
I use Shell Rotella T 15-40 in all my vehicles. I used Havoline 10-40 for years before that.
I do not use Synthetic...
I don't think I'd say they're all equal. There are tests that show some break down a LOT faster than others, some don't cling to parts well resulting in scarred engine parts due to metal on metal, etc. Not trying to be argumentative, but there are pretty conclusive tests showing good and bad points of some of the oils out there.
Old Oct 4, 2006 | 10:41 PM
TahoeSS01's Avatar
Not to argue-just my own exp with Amsoil and I have customers who swear by it.
I had a bad issue with Amsoil 10-40 with their filter on a new motor.
I did filter swap at rec 7500k and topped off as per Amsoil.
At 11000 miles eng failed.
Engine dropped valve due to broken valve retainer but sent oil sample to Amsoil,Castrol and a indy lab anyway.
Both Indy and Castrol said oil was "clumped" due to improper blending of inert elements of the oil additives.They also said oil was on the verge of the vis of a stright 50wt.
Amsoil never replied even though I was a stocking Amsoil dealer.
Also had a issue with a 770r4 trans and od hunting with Amsoil(cust supplied Amsoil)-changed back to Dextron problem gone. Customer couldn't beleve it also(he is a Amsoil only guy)
Swapped to Royal Purple since with out any issues.( and also trying Klotz in my truck now).
The Amsoil site doen't test Royal ,Torco, Redline, Klotz or I missed it.
http://www.bestsynthetic.com/comptest.shtml
Not saying Amsoil is bad-just some of the few things I had happen to me over the years .
I stand corrected they do a comp test on red line and rp but with 20-50 racing oil which we don't use in our trucks.
Use what you feel is best no oil will keep it from blowing up under over extreme measures and change it at 3 -5 k max.
Old Oct 5, 2006 | 03:56 PM
treyZ28's Avatar
I just use mobil one and forget about it. You dont need more, even if the others are actually better.
Its been tried and true to 200k+ miles. I'm not at all worried about spinning a bearing or wearing rings before that.
Old Oct 5, 2006 | 10:17 PM
budhayes3's Avatar
PT's Slowest Truck
I've had good luck with Mobil1 fully synthetic...it's a little more expensive than the dino oils, but cheaper than Amsoil and Royal Purple (which I don't have personal experience with). If you keep your eyes open, you can find Mobil1 on sale at either WalMart or Kmart pretty often.
Old Oct 5, 2006 | 10:39 PM
redwagon's Avatar
if you've run regular oil for any extended period of time, switching to a cleaner synthetic will take several changes to flush all the "impurities" out of the motor. i''ve run mobil 1 for the past 6 changes.
Old Oct 5, 2006 | 10:51 PM
jakebdb56's Avatar
castrol syntec in my truck, royal purple in the buggy . haven't really noticed any "advantages" thus far with the buggy. Personally I can't see any reason why I should switch from the regulare ole stocky pennzoil **** to synthetic... only reason I went castrol syntec was the rebate from oreillys lol
oh and i forgot to add, if you're inquiring about oil filters (i forgot what the post was referencing in its entirety due to my miller juice) I always use fram because of the nice design, it looks purrrrrdy
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 04:22 PM
lxcoupe
Sep 25, 2015 12:36 PM
69z-28
Sep 21, 2015 07:31 AM
Velocity1
Sep 15, 2015 11:29 PM
