Oh Shit! Did I cook my engine?!
Old Dec 30, 2008 | 10:52 PM
Derek @ EDO's Avatar
FormerVendor
You should be fine, i've done that before along time ago.. I left my truck running only to find it killed with steam coming from under the hood with the temp gauge pegged out.
When I first noticed i thought it was on fire until I saw the "smoke" dissipating into the air then i realized it was steam... I had the fire extinguisher ready!
Thats right, it got so hot it died on its on... I thought for sure i was F&*^%D but I let it cool and fired her back up.. It ran some 11 second passes after the fact so im sure it didnt harm a thing. Scary feeling though!
Old Dec 30, 2008 | 10:54 PM
KevinF56's Avatar
**** that makes me feel better.
hey i actually have one of your e-fan harnesses. if a relay happened to go out, would the fans not work?
Old Dec 30, 2008 | 10:55 PM
BlownChevy's Avatar
blownerator
25 Year Member
fire it up, if it runs you are good!
Old Dec 30, 2008 | 11:03 PM
silver-mod-o's Avatar
Hunt&Fisherator
When mine has gotten hot, I've always tried to fine the nearest long stretch of road, run it up to speed, and let it idle/coast.... I know you couldn't exactly do that.... But killing it with it that hot let's it just sit there and bake... Not good, but I agree with everyone else, I think you'll be ok.
I'm just paranoid because I've warped heads and intake manifolds like that.
FormerVendor
Yea, its possible.. Test the harness. Tap into the PCM trigger wire and run it to ground. If it does not work it could be a relay issue.
If there is a problem let me know and ill send you some relays ASAP.
Old Dec 30, 2008 | 11:11 PM
KevinF56's Avatar
yeah that's what i'm worried about... i totally forgot about the intake manifold and it being plastic or whatever it is. i hope i didn't melt it. this thing was crazy hot.
ok i'll let you know. thanks man.
Old Dec 30, 2008 | 11:38 PM
tglandon's Avatar
I have heard that the remote will work over the phone.
Old Dec 30, 2008 | 11:41 PM
00ChevyScott's Avatar
Wearin' da big hat
lol............
Old Dec 30, 2008 | 11:43 PM
95 bright teal's Avatar
No seriously the remote is a audio frequency
Old Dec 30, 2008 | 11:45 PM
Wearin' da big hat
id have to see it to believe it.
