Official NBS V6 to GENIII V8 swap Guide
Old May 4, 2010 | 09:01 PM
  #61
ssinister04's Avatar
fromt he pedal to the module there should be a small maybe five wire or so harness connecting the pedal to the module..
im trying to figure out where in the engine compartment the module monts to..over on gmfs i have no repsonse
Old May 4, 2010 | 10:10 PM
  #62
Cook's Avatar
i have it. it mounts on the drivers side upper of the firewall
Old May 4, 2010 | 10:15 PM
  #63
Cook's Avatar
ull see it
Old Aug 8, 2010 | 03:35 PM
  #64
rathgeber0's Avatar
Do you know if the 5.3 in the 03 silverado are the same as the 03 express?
Old Aug 9, 2010 | 01:38 PM
  #65
Cook's Avatar
it should be. theres a huge difference when going from 99-02 to 03 and another difference when going 03-04+
another thing we noticed is the parking switch on the transmission is different, as well as the ac canister
Old Aug 9, 2010 | 08:06 PM
  #66
2005 Silverado's Avatar
SPAM HUNTER
The canister is i had to replace mine, and the switch like the neutral safety switch? is it 1 connector instead of 2?
Old Aug 10, 2010 | 08:48 AM
  #67
Cook's Avatar
yeah i kept my 6cyl one but we went the ac line out of the way of the oil dipstick. the yeah the switch on the side had one big connector vs 2 so we had to replace it.
Old Aug 11, 2010 | 08:24 AM
  #68
Syclone354's Avatar
10 Second Club
Just wanted to jump in here again. I just successfully drove our 2001 Silverado ECSB home last night after swapping from the 4.3 to a 6.0 and 4l80e trans. It was definitely worth the work!
I picked up a mostly complete 2001 2500hd SCLB that was wrecked. I used the motor, trans, harness, ecu. I had to get a different yoke for the driveshaft, "merge" the fuel lines and trans cooler lines, cut out the crossmember mounts and drilled/bolted the 2500 trans crossmember to frame, and then do the security relearn.
Runs and drives great! Only code i have is for oxy sensor bank 1 sensor 2 cause it isnt there yet .
Old Sep 10, 2010 | 10:41 PM
  #69
BadAssBowties's Avatar
Ok i have read every post in this thread and i still have a problem that has yet to be brought up. I have a 04 rcsb 2wd silverado. Its a 4.3/5 speed truck or was anyway. I picked up a 2000 2500 6.0 and 4l80e to drop in it. The problem im having is the frame mounts. I know the 4.3 mounts wort work so i too them out and tried to put the 2000 6.0 mounts in but that isnt happening. I figured it was because of the 3/4 ton frame so i went to the junk yard and the only thing i found was a 03 5.3 2wd tahoe so i bought the mounts. Guess what lol the pass side will bolt in the the drivers side it a little over a inch to wide and the bolt hole on the frame are a inch wider than the holes in the mount. Im lost and thinking im just going to have to either build some to fit or order a set of 04 5.3 mounts from a dealer. I really dont want to go to the dealer so someone please help. Thanks
Old Sep 11, 2010 | 12:32 AM
  #70
Krazy Ken's Avatar
I ran into the same problem on my swap. You have to get the corresponding frame mounts as your vehicle. The drivers side frame mounts from a 2wd to a 4wd are different. I believe the 2wd is longer like the one your talking about. I ordered the 2wd for my 4wd on accident from the dealer but swapped it for the correct one once i figured out the error. They changed it to clear the front diff. on a 4wd. Hope this helps.
