Octane Booster
Old Mar 23, 2004 | 10:53 PM
TwoFast's Avatar
Default Octane Booster
Has anyone used octane booster in their trucks? Any power increase? Can it be used with a HPP3? Does it help the engine burn more efficiently/ better mpg? Thanks
Old Mar 23, 2004 | 11:08 PM
BlownChevy's Avatar
blownerator
25 Year Member
Snake oil! Not good for ANYTHING in your truck......Valves, Cats, O2's. Save your money and the harm to your truck.
Old Mar 23, 2004 | 11:13 PM
parish8's Avatar
single digit dreamer
they will help if your runing boost but only if you dump it in like 5 gallons at a time
Old Mar 23, 2004 | 11:21 PM
Hit Man X's Avatar
It will adversely effect performance if you aren't tuned for it as it doesn't burn too efficiently. Besides that **** in a can from the parts store may raise your octane .2-.7 now a REAL boost would be tossing in some toulene or xylene in a one gal of that for every 4-5gal of 91+ gas.
Old Mar 23, 2004 | 11:22 PM
BlownChevy's Avatar
blownerator
25 Year Member
That IS money well spent.
Old Mar 23, 2004 | 11:26 PM
parish8's Avatar
i have dumped in xylene 5 gallons at a time many times, it wont help unless you turn up the boost though, and it sounds like you dont have and of that to turn up.
Old Mar 23, 2004 | 11:51 PM
getsome's Avatar
If you you use xylene (paint thinner) do you have to had like anything to lube it because that stuff is kinda dry?
Old Mar 23, 2004 | 11:54 PM
Hit Man X's Avatar
The fuel in the tank mixes with it. I believe it's like what 117 octane by itself?
Old Mar 24, 2004 | 02:51 AM
sleepersilverado's Avatar
i think parish was putting trand fluid in there or something i dont remember but i am sure he will chime in tomorrow.
Old Mar 24, 2004 | 06:29 AM
parish8's Avatar
yes i was using tranny fluid but i see marval mystey oil recomended alot too. can't remember the ratio though.
