O2 Sim Question
Old May 18, 2005 | 06:32 PM
shandy294's Avatar
Default O2 Sim Question
Can they be made easily using a resistor and connector or is there more to it than that? Any help appreciated.
Old May 18, 2005 | 10:33 PM
shandy294's Avatar
Oh well,thanks for the information.
Old May 18, 2005 | 11:32 PM
white1's Avatar
Not that I'm aware of. I think they actually read o milivolt signal. They are pretty much a cheap o2 analyzer. Good luck finding out for sure though.
Old May 19, 2005 | 05:03 AM
FIREHAWK #07's Avatar
I once also wondered the same thing...... but i searched and found nothing!!! so i just bought the o2 sims....
Old May 19, 2005 | 09:50 AM
02chevyracing's Avatar
14 Second Truck Club
i have a pair of o2 sims for sale just took them off my 02 silverado cause i got a tune asking 55 shiped pm if you interseted thakns Gene
Old May 19, 2005 | 10:14 AM
LedFut's Avatar
O2 sims are tricky. You should spend the extra little bit of money and get the good ones that cross-count. They will vary their millivolt readings slightly to show that the "cat" is still doing its job correctly, even though its not there. The cheap ones just give a constant O2 reading, which will eventually set off your Check Engine Light.
ONLY use the O2 sims on the back O2 sensors, NEVER on the front ones. The front O2 sensors are there to tell the computer how rich or lean the A/F ratio is. If you put an O2 sim here, it would tell the computer false information that would probably destroy your engine. Hope that helped a bit.
Old May 19, 2005 | 05:07 PM
shandy294's Avatar
Thanks for the info in your first paragraph. I knew about just using them in the rear. I might get headers someday,that's why I was asking.
BTW,how much do good ones cost?
Old May 19, 2005 | 05:09 PM
shandy294's Avatar
Gene,I'll keep that in mind. Don't need them at this time;thanks for the reply.
Firehawk #07...thanks for the reply.
Old May 19, 2005 | 11:29 PM
LedFut's Avatar
good ones usually go for $80-100.
Hope everything works out well! Good luck!
Old May 20, 2005 | 12:49 AM
shandy294's Avatar
Thanks, guys ,for the replies.
