O2 sensor and TPS sensor output wires?
Old Dec 18, 2003 | 09:30 PM
O3GMC's Avatar
12 Second Club
Default O2 sensor and TPS sensor output wires?
I need to know which colors to tap into so I can install my tps voltage WOT switch and an air/fuel guage.
Thanks
Old Dec 19, 2003 | 03:07 PM
O3GMC's Avatar
12 Second Club
ttt anyone know which wires are the output wires for the throttle position sensor or o2 sensor?
And by chance does anyone know the voltage of the tps when at WOT ? my NX activation switch needs 4 + volts
Old Dec 19, 2003 | 03:21 PM
LOW2000's Avatar
For a 2000, looking at the schematic, I believe its Dark blue for the sensor signal, grey for the TP sensor 5V and black for ground.
YMMV
Old Dec 21, 2003 | 04:26 AM
eallanboggs's Avatar
Blue wire on TPS. Use a small sewing needle to pierce the insulation on the blue wire. Attach an alligator to the needle and the lead on your DVOM. I think the voltage is just over 5 VDC at WOT. You can look in the shop manual to be sure of the WOT and closed throttle values.
Old Dec 22, 2003 | 03:09 PM
O3GMC's Avatar
12 Second Club
My voltmeter turded out........so I called the dealer and one of the techs looked it up.........but he said there were 2 sensors, 3 wires each, and that the grey and light blue were the 5V wires, but one side was from low to high and the other from high to low.........I guess meaning that one reads 5V at WOT and the other at closed throttle. So..........any more info? He also said that the bank1 o2 sensor signal wire was purple/white
this is drive by wire too.......just FYI
Old Dec 25, 2003 | 09:37 AM
O3GMC's Avatar
12 Second Club
ttt - before I make this last connection, anyone have a manual for a 03 drive by wire so I can make sure I'm splicing into the right one? My guess is the blue right out of the throttle body harness, would just like to be sure. Thanks
Old Dec 25, 2003 | 10:12 AM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
It's the Dark Green wire in position "G".
Old Dec 26, 2003 | 01:02 AM
O3GMC's Avatar
12 Second Club
speartech, is this for a 2003 drive by wire tps ?
Old Dec 26, 2003 | 01:11 AM
Speartech's Avatar
Yes, with the single 8-way connector on the side of the TB. Position G is TPS #1 signal.
