O2 Problem??? NEED SOME HELP!!!!!
Old Dec 30, 2008 | 02:41 PM
  #31
35 what??? Sounds like it's lazy should switch back and forth like the other side...
and the MAF sounds like it needs to be replaced...
Sorry, 35 degrees. Getting a MAF today.
Old Dec 30, 2008 | 09:56 PM
  #32
1FastBrick's Avatar
Custm2500's Rude Friend
35 degrees... obviously there is a problem with that sensor....
Old Dec 30, 2008 | 10:22 PM
  #33
Thats kinda what I was thinking. I am about to put another sensor and a MAF in this weekend and hopefully it will all go away.
Old Dec 30, 2008 | 10:30 PM
  #34
1FastBrick's Avatar
What was the temp out side when you were running the test???
Old Dec 30, 2008 | 10:36 PM
  #35
about 60 degrees. Thats why I don't understand it.
Old Dec 30, 2008 | 10:46 PM
  #36
1FastBrick's Avatar
LOL well I kinda figured you weren't out side at -27... Its obviuosly not reading correctly and may not be reading the proper flow of air going through it. Same problem with the O2 sensor if its not heating up properly then It's not functioning properly.
BTW Just in case you did not know, Always make sure the vehical is up to it's full operating temprature while your checking sensor functions with a scanner.
Sounds like you did but I just want you and others to be aware in case they did not know
Old Dec 30, 2008 | 10:51 PM
  #37
Yeah I drove it about thirty minutes to get to the shop. Could just the MAF make the truck run really bad like it has a miss. Also, could the MAF cause the computer to throw an O2 code? Or is this just my O2???
Old Dec 30, 2008 | 11:01 PM
  #38
1FastBrick's Avatar
Maf would cause it to run like **** but the fact that the one sensor was only reading 35 Degrees and the codes I would say its bad too.
Old Dec 30, 2008 | 11:11 PM
  #39
Ok. I will let you guys know when I get the MAF in. Until then I will just hope and pray that this will fix it. Thanks everyone!!!!!
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
