O2 Problem??? NEED SOME HELP!!!!!
Old Dec 28, 2008 | 10:41 PM
  #21
I reset everything this morning. I put about 150 miles on it today. Now I am just having codes P0101, P0154, and P0155.
Old Dec 28, 2008 | 10:44 PM
  #22
GMCtrk's Avatar
How does it drive?
Old Dec 28, 2008 | 10:52 PM
  #23
Originally Posted by GMCtrk
How does it drive?
When you are wide open, you can tell that it isn't 100%. Then it will all of a sudden have power for about 1/2 a second then bog back down again. I am also getting horrible gas mileage.
Old Dec 28, 2008 | 11:02 PM
  #24
GMCtrk's Avatar
Did you get a computer on there and check the A/F ratio?
Was the stock pcm changed for a different one when it was tuned or did the tuner tune your stock pcm?
Old Dec 28, 2008 | 11:08 PM
  #25
1FastBrick's Avatar
Custm2500's Rude Friend
did you unplug or plug in any of the conections while the Key was on??? That can cause a voltage spike and damage the components... Have you put another sensor on it???
Yes you can check the voltage and the resistance on the sensors, but I dont have any of that info in front of me right now...
Old Dec 29, 2008 | 11:09 AM
  #26
No. I just took it out and met him at my buddy's shop. He did everything there.
No I did not unplug anything while the truck was on. I disconnected the ground, then installed the headers, then plugged everything back up, then reconnected the ground. And yes, it has brand new sensors on it now. I was getting P0134, P0135, P0154, P0155. After I put new ones on I am only getting P0154, and P0155.
I am going to check voltage and resistance later tonight. I wish I had a service manual to tell me what it is all supposed to read.
Old Dec 29, 2008 | 11:10 AM
  #27
Does anyone have this info???
Old Dec 29, 2008 | 06:04 PM
  #28
I just hooked it up to a GM diagnostic reader. After warming the truck up, Bank 1 sensor 1 is only reading 35 at idle. Bank 2 sensor 1 is reading a little over 400 and appears to be working properly on screen. MAF was reading -27 degrees. So does anyone think that the MAF could be the problem?
Old Dec 29, 2008 | 06:05 PM
  #29
I just really want to get this figured out. I am really looking forward to installing the cam and converter. I just want to get this out of the way first.
Old Dec 29, 2008 | 11:59 PM
  #30
1FastBrick's Avatar
35 what??? Sounds like it's lazy should switch back and forth like the other side...
and the MAF sounds like it needs to be replaced...
