O ring Nightmare!!!!
Old May 30, 2006 | 09:36 AM
FarmerBeau's Avatar
Sexy Party Mod
Default O ring Nightmare!!!!
After completing my camswap, i noticed that my oil pressure was significantly lower than normal. I dropped the pan again this morning to find half of the o-ring bunched up and busted. I CANT FIND THE OTHER HALF OF THE O_-RING!!!!!. Where the hell could it be? Is there a possible way that the oil pump could have shoved it up into a galley or something? Im freakin out man!! Im heading to class and then im gonna pick up a new o ring on the way back.
BTW- I found it easier removing the crossmember and pushing the steering components out of the way when removing the pan itself.
Old May 30, 2006 | 10:44 AM
white1's Avatar
Its probably in your filter, or working its way there. Cant be any worse than the bolt I had in my oil pan a while back
Old May 30, 2006 | 11:02 AM
bluecajun5.3's Avatar
11 Second Truck Club
what did you do? change the oil pump too when you changed the cam? i hope you find it or find a solution for the problem
Old May 30, 2006 | 12:10 PM
negativeswitches's Avatar
may have fell in you pickup tube
Old May 30, 2006 | 12:14 PM
Nick™'s Avatar
he put a LS2 timing chain
Old May 30, 2006 | 02:57 PM
FarmerBeau's Avatar
Sexy Party Mod
i have the pickup tube out of the truck now and its not in there. I was thinking about dropping the windage tray for safe measure while im there. Just got back from the dealer with 2 new gaskets again just so my dumbass didnt have to run back in case i screw up!
Old May 30, 2006 | 05:40 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Dont worry about it. It got chewed up by the pump rotor and its already done its damage dont waste your time looking for it. If you want you can pull the oil pfilter and and cut it open and look for bits and pieces of it in there. Hate to say it Beau but I told you to BE CAREFUL and you didnt listen
Old May 30, 2006 | 05:50 PM
white1's Avatar
Stupid punk *** kids hugh Cody, never listen to the words of experience. I didnt even tell him "I told you so"
Old May 31, 2006 | 12:02 AM
FarmerBeau's Avatar
Sexy Party Mod
I found the rest of the oring chewed up in the oil filter. I was releived! And Cody, you were right!!!! Im sorry.
I figured out what i did wrong; I put the damn o ring in the pump and then stuck the tube in the pump rather than putting the o ring on the tube itself. I would recommend dropping the fuggin oil pan (completely) for anybody that hasnt done it just for safe measure to avoid the situation that i went through. I took off the pickup tube and first got the o ring adjusted, actually threading the bolt in with my hand and fine tightening with a socket, then adding the nuts to the studs on the bottom of the windage tray. Everything is good to go now and its Penut Butter Jelly Time!!!!!
Old May 31, 2006 | 12:07 AM
meatwad's Avatar
Fast lane preferred
Congrats Beau. Glad you got it figured out.
Cody, I think the o-ring f'ed up cause Beau was distracted by Jack and his endless drunken tomfoolery.
