Now attempting 2-bar SD: Problems and questions!
Old May 16, 2005 | 03:49 AM
BlownAlaskan's Avatar
Default Now attempting 2-bar SD: Problems and questions!
Im a complete newb at this except for what I have been able to read in my research efforts over this last couple of weeks, so any and all help appreciated.
Basically, I set SD parameters(I think) and then tried to start the truck, w/out the maf. I will list the steps I have taken below:
1: Set maf fail to 0 and disabled the SES lights for MAF codes P0101, P0102, P0103, P0106-P0108 set to 'x' and No MIL
2: (CAFR = 12.1) changed all points to 1.21
3: Disabled closed loop
4: Copy High Octane table to the Low Octane Table
5: Disabled PE mode
6: Scaled MAP scaler to read 50kPa when key on, ended up with value of 93.0, with my sensor.
7: Bypassed the barometric pressure updating
Next, I cleared the fuel trims and tried to start the truck. It started, but would hardly run and was trying to idle at around 400 rpm, with the wideband showing like 16:1.
Here are a few of my present questions:
1: What other tables do I need to change to reflect the new "halved" map values? Ross(EFILive) mentioned something about the LTFT matrix etc.
2: What else do I have to adjust to get a reasonable idle?
3: Once I get the VE 'auto-adjusted'(EFILive) what do I do next as far as fueling goes? Do I just re-enable closed loop and PE?
4: I know I have other questions I forgot about, but these are the ones that come to mind.
Thanks in advance for any and all sugestions.
Old May 16, 2005 | 10:34 AM
02sierraz71_5.3's Avatar
https://ls1tech.com/forums/showthread.php?t=304025
You would get more replys in the pcm section above is a link that outlines steps on what to do numbers 2 and 6 sound off Ive been doing research also on the topic and some people sware by tuning stft method its alot easier that ltft tuning.
Old May 16, 2005 | 01:37 PM
Thanks for the link, that is a good read.
Number 2: For now, I want to command 12:1 AFR being forced induction, that is why you always see a different value in the guides.
Number 6: Some amount of table scaling has to be done for the 2bar sensor to work correctly.
Ben
ferrellrooster
Mar 6, 2025 03:22 PM
chevy6.0fan
Aug 20, 2015 07:10 PM
05GMC4.8
Aug 7, 2015 09:55 PM
USMCvet0311
Aug 1, 2015 07:45 AM
grantpo
Jul 15, 2015 12:21 PM
