Not running right after heads replaced
HP Tuners can log the MAP voltage, you just need to pick that specific channel to view.
https://www.lt1swap.com/gen3_schematics.htm
https://www.lt1swap.com/99-02_vortec_pcm.htm
Possible gross intake leak? You can check MAF flow rate and IAC position compared to a pre-headjob scan to see if both are bottomed out. It is a stretch as a leak causing a true 102kpa manifold vacuum would idle really high but the low MAF reading may prevent enough fuel to rpm, thus the popping and rough idle.
chunkee
Feb 22, 2010 05:06 PM
2000 SILVERADO
Apr 22, 2008 08:47 PM
