Lifting the heads!!!
Old Jun 1, 2005 | 08:25 PM
Flyer's Avatar
Default Lifting the heads!!!
Had another gasket leak on the heads. It was getting bad like last time where it was burning coolant on a cold start. Anyways, I pulled the heads and noticed that BOTH sides are lifting and blowing past on the outside of the motor, only one side was burning coolant.
WHat head gaskets are the bigger power motors using and having success with? I've been using GM MLS 6.0 gaskets. This is the 3rd set fixing to go on, and I don't really wanna do this again.
Pics to come later.
Old Jun 1, 2005 | 09:53 PM
Steve Bryant's Avatar
LS1 Tech Veteran
I think that besides making a gasket choice, you might want to check your heads for straightness and maybe your cylinder decks too. This will require an engine straight edge and feeler gages. If your heads are warped significantly, head gaskets won't solve the problem. Also, why are you using 6.0 L gaskets designed for a 4.000" bore when your 5.3 L has a 3.779" bore? This alone might be causing significant head gasket sealing problems.
Steve
Old Jun 1, 2005 | 10:09 PM
99Silver6.0's Avatar
Might be time to look into some Cometics. I see more and more LS1 guys using them. Down side is they are pretty expensive. Are your heads studded??
Old Jun 2, 2005 | 12:47 AM
Flyer's Avatar
I guess I should have given a little more info, it's a 5.3 with 6.0 heads on it. That's the reason for the 6.0 gaskets. I thnk I'm gonna try using some lube and a little different torqueing process that someone mentioned on the heads.
Yes, they are studded.
The heads aren't warped, if that were the case, I would think it would be one or 2 cylinders, not all 4 on both sides on the outside edges. You can see the charred gasket on the head side on all 4 on one side and the back 3 on the other side, and one cylinder on the one that was leaking coolant on the block side. The last time this happened it was on the opposite side from the one that's now leaking. The heads were not swapped from last time either.
Since I already have the MLS gaskets, I'm gonna give them a shot again using a little more torque, 85 instead of 75. I also have to have this done by tomorrow, early Fri evening at the absolute latest.
Old Jun 2, 2005 | 08:51 AM
F8L Z71's Avatar
That's wild bro. I was using the stock 6.0L gaskets and didn't have any problems at 14psi. You're just a savage!
Old Jun 2, 2005 | 09:21 AM
O3GMC's Avatar
12 Second Club
Are there any problems running the 6.0 heads on a 5.3? I could buy a set for cheap, but I'm thinking different bore size....
Old Jun 2, 2005 | 09:30 AM
F8L Z71's Avatar
No problems here. Worked great for me and Flyer.
Old Jun 2, 2005 | 12:51 PM
Flyer's Avatar
The performance is awsome, for boosted apps, but I've had problems with head gaskets though. I do spin my up pretty high for a stock motor though. 6600 shift points and 6900 rev limiter.
Old Jun 2, 2005 | 01:32 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I'm using MLS gaskets too. Did you over-torque your heads? Studs or bolts?
Old Jun 2, 2005 | 01:39 PM
hellbents10's Avatar
LS1Tech Sponsor
You have a detonation problem? as this is the only reason you should be lifting your heads if you are.
