Noob question
Old Aug 8, 2004 | 02:19 AM
six7one's Avatar
Default Noob question
Hi I'm new here and lookin to buying a 99+silverado RCSB and was wondering where can I buy a LQ9 motor and is there any supercharger application for this motor.
Thanks
Old Aug 8, 2004 | 02:54 AM
gcooper's Avatar
Oh you can buy a supercharger for that bad boy... radix, whipple, vortec, etc. And i think there might even be one for sale somewhere on here.
Old Aug 8, 2004 | 06:32 AM
GREGGO's Avatar
Look to the right at the sponsors. Several of them make engines for these trucks. Basically any motor for the car will fit in the truck. As for a LQ9 specifically, look at SDPC over to the right. They are the official GM part provider to LS1Tech. Ebay is another place and in this sites clasifieds. Superchargers>>>>>>>>>>>>>>>>>>>>> Yep, to the right>>>>>>>>>>>>>>>
Old Aug 8, 2004 | 05:27 PM
six7one's Avatar
Thanx for the info but I've got a couple more question.
When swaping the motor what would I need if the truck had a V6 4.3 or a V8 4.8/5.3 engine in it to begin with.
Old Aug 8, 2004 | 09:48 PM
Swap would be much easier if you get a truck with a v8 from the factory. If you plan on supercharging you would be better off getting the LQ4 6.0L that is rated at 320hp because it has less compression, and you would be able to run more boost safely.
Old Aug 9, 2004 | 03:54 AM
six7one's Avatar
My 408cid parts list
6.0 bored over .030
Lunati 4.00'' crank/rods
JE pistons
Patriots stage II heads
Comp cams valve train
224/230 .580 115lsa
LSX 90mm manifold/TB
100/50 Direct Port
Fuel system???
What size fuel injectors for this set up.
JordanH
Dec 25, 2015 08:32 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
carid
Sep 10, 2015 09:07 AM
