Noob question
Look to the right at the sponsors. Several of them make engines for these trucks. Basically any motor for the car will fit in the truck. As for a LQ9 specifically, look at SDPC over to the right. They are the official GM part provider to LS1Tech. Ebay is another place and in this sites clasifieds. Superchargers>>>>>>>>>>>>>>>>>>>>> Yep, to the right>>>>>>>>>>>>>>>
Swap would be much easier if you get a truck with a v8 from the factory. If you plan on supercharging you would be better off getting the LQ4 6.0L that is rated at 320hp because it has less compression, and you would be able to run more boost safely.
My 408cid parts list
6.0 bored over .030
Lunati 4.00'' crank/rods
JE pistons
Patriots stage II heads
Comp cams valve train
224/230 .580 115lsa
LSX 90mm manifold/TB
100/50 Direct Port
Fuel system???
What size fuel injectors for this set up.
6.0 bored over .030
JE pistons
224/230 .580 115lsa
100/50 Direct Port
Fuel system???
TAPyvehc93
Sep 12, 2015 08:19 PM
carid
Sep 10, 2015 09:07 AM
