NON vortech 350 to vortech 496ci swap?
Hey guys,
I have a quick question for you,
What all would be needed to swap out a broken non vortech 350 out of a 95 Hummer H1 in favor for a 496 ci (8.1L) vortec motor out of a newer 2500/3500 truck.
Thansk
Shawn
Thansk
Shawn
if you have time and money anything is possible....
motor
motor mounts
all wiring from a 2500/3500
allison or 4L80 tranns (or that big 6 speed Z something or another dont remember the model #)
without looking i would say it would be a total custom setup... but it is possible...
motor
motor mounts
I think they come with a Th400 in the early years, 91-93 then 94+ have the 4L80E. The final years have a dmax allison but they are about still about $130K used which is crazy.
Ive seen a few 6.0L or 8100 on e bay with the wireing harness, so i would think it should just "sorta" simple.
I've never seen a gas-powered Hummer. With a 350 L05 that thing must be a dog.
I might suggest you install a Vortec 454 instead for a few reasons. First of all, you've already got a 4L80-E in there and you'll need the right wiring harness to control the engine and the transmission. With an 8.1 that limits you to finding a 2500 BigBlock Suburban, Yukon, or Avalanche harness. Also, the Mark VII bigblock is a strange thing. It has symetrical intake ports unlike every other big block, and that allows for the two extra "missing" headbolt holes. So, the heads are of course proprietary, as-is the intake manifold. There's no distributor, the 8.1 has a coil per plug like the Gen-III/IV smallblock, so the valve covers can't easily be swapped out for others without taking that into consideration. The 8.1 water pump is also specific, so aftermarket stuff doesn't work here either. Mark-VII heads have a totally different cooling arrangement - water actually exits the ends of the heads and the intake manifold has nothing to do with it. The 8.1 also has a weird firing order, so no regular roller bigblock cams work in it.
With a Vortec 454 you get a Mark-VI bigblock that an entire world of aftermarket heads, rotating assemblies, valvetrain, and all kinds of other parts are readily available for. All Mark-VI bigblocks are 4-bolt mains, so every production L29 Vortec 454 is 4-bolt. These have one-piece seal cranks and accept heads from other generation big blocks.
Every production Vortec 454 (1996-2000) with an automatic came with a 4L80-E or a 4L80-EHD, so about the only thing you'll have to pay attention to with the wiring harness is 4WD or 2WD.
I think a 454 would be easier and a better platform for modifications. Just my opinion. I've got one and am definately a fan of the L29.
Last edited by James B.; Feb 14, 2008 at 08:36 PM. Reason: Changed some verbage... can you find it?!
Good greef James, Your a walking 8.1 dictionary arent you!
To be honest with you motor wise i dont care, Just seem's intoday times it would be smarter to go with something bigger than rebuild that 350. You all know how slow a truck / tahoe was back in the early 90's... now make that
10,500 lbs!
The H1 is full time 4wd or awd... so i guess a two 2WD harness would work... or i could change the transfercase and so i have 2wd 4hi and 4lo...
Ive seen a few 502 swapped in but they all have a carb.
10,500 lbs!
I just dont want a carb, we live in the mountains so the temp can be anywhere from 0 to 90*
Yesterday alone the tempatrue was 60* at 7:30 am, 30* at lunch at 18* last night...
That and i have never had any good luck with 4 wheel a carb.
So if the ticket is a 454 motor where is the best place to start looking for it.
