NNBS PCV Tube
Old Jun 26, 2013 | 07:26 PM
axekick's Avatar
Default NNBS PCV Tube
I need to know the part number for the NNBS PCV tube. I speciffically need the part that plugs into the top of the intake but I heard that came with the whole tube. I've got my NNBS intake swap rigged up with a brass fitting and an o-ring but I just discovered that my o-ring is broken. I was wondering why I couldn't get fuel trims dialed in exactly right. Anyway, does anyone know the part number or have any info on the subject?
Old Jun 26, 2013 | 09:02 PM
Whitecrewcab's Avatar
Any decent parts counter guy should be able to look it up, took the guy at the dealership here in El Paso like 2 minutes tops. It does come with the whole tube, but if you don't have the late style valve covers, you will probably have to cut off the quick connect on that end and just use a piece of rubber hose.
Old Jun 26, 2013 | 09:29 PM
axekick's Avatar
Right on. Thanks for the info. That will be better than my current setup.
Old Jun 27, 2013 | 12:09 PM
axekick's Avatar
Dammit. I just got back from the parts place. They brought me out my part and it was only the tubing. It didn't include the piece that goes in the hole on the top of the intake. I guess I'm stuck with my rigged up setup.
Old Jun 27, 2013 | 01:26 PM
axekick's Avatar
I got it! You have to look for the crankcase ventilation tube from an '10 or newer. The part number is 12597774
Old Jun 27, 2013 | 02:04 PM
I think I told him from an 09, but should be the same thing lol. Glad ya figured it out.
lucas287
31
Jan 12, 2021 06:18 AM
natejk
Nov 15, 2016 08:05 AM
chvy=power
Oct 20, 2015 09:08 AM
11MPG
Sep 8, 2015 04:52 AM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
