nnbs 4.8 comp?'s
Old Nov 10, 2011 | 10:25 AM
myth's Avatar
Default nnbs 4.8 comp?'s
I have been searching but have come up empty. A couple of questions. Does the piston come out of the block on TDC? If so how much?
Im kicking around the idea of raising the compression on the little 4.8. Thinking about going with a .030 head gasket and milling the heads. I would like to get the compression to around 10.5. Not to worried about PTV issues. Cam is a 218/222@.50 .530/.567 lift.
Any thoughts please.
Old Nov 10, 2011 | 10:27 AM
SweetS10V8's Avatar
Typically on LS style engines, I have seen that the pistons stick out of the hole .006-.008"
Old Nov 10, 2011 | 10:31 AM
myth's Avatar
Thats what I am thinking but cant find anything to back it. If it is out of the hole then the .030 gasket will but the quench a little closer then I care to be.
How are things going in Michigan?
Old Nov 11, 2011 | 08:04 AM
myth's Avatar
How much of increase will 1 point of compression make?
Old Nov 14, 2011 | 08:26 AM
Harbinz51's Avatar
Compression usually adds torque .Im sure a small shot of Nitrous would wake your truck right up to where you want to be
natejk
Nov 15, 2016 08:05 AM
chopperloco
Sep 28, 2015 08:40 AM
gmcyukon
Sep 11, 2015 10:33 AM
11MPG
Sep 8, 2015 04:52 AM
USMCvet0311
Sep 4, 2015 09:43 PM
