The NGK Spark Plug Thread
Old Jan 4, 2011 | 10:53 PM
  #31
dmelvin's Avatar
Originally Posted by AKlowriderZ71
I just found this thread using the SEARCH button!!
You know, there will be someone within the next month asking about these plugs, because they didn't click the SEARCH button.
Old Apr 30, 2011 | 08:17 AM
  #32
ChevyTruck's Avatar
something else
May be a dumb question But what are the different heat ranges used for?
Old Apr 30, 2011 | 08:29 AM
  #33
dmelvin's Avatar
NO2 / NA / FI / Different fuel applications
Old Apr 30, 2011 | 08:53 AM
  #34
00ChevyScott's Avatar
Wearin' da big hat
As you add horsepower, the temperature in each cylinder increases. Going to a colder heat range allows more heat to flow through the spark plug and into the head, which decreases the cylinder temperature.
Old May 2, 2011 | 10:40 PM
  #35
LS1TRUCKGUY's Avatar
i have a 5.3 with a cam and nawz. what heat range should i use? also what should i gap them to?
just kidding..... someone had to do it
Old Jun 20, 2011 | 08:28 PM
  #36
04SilveradoMykk's Avatar
No use in starting a new thread about this.
In my engine, based on how these plugs look. Would you use the TR55 or the TR6:
The ground straps are modified, not eroded away.
TR6 from cyl #1 on the left, TR55 from cylinder #2 on the right. Both plugs have the same mileage and use on them.
The TR55 appears to have a cleaner porcelain, yet on the ground strap by the base has more carbon than the TR6. Neither of the plugs are showing any detonation, which is really good
What would you run?
Old Jun 21, 2011 | 01:11 AM
  #37
AKlowriderZ71's Avatar
11 Second Hall Moniter
To really read a plug correctly, you've got to cut it open.
Old Jun 21, 2011 | 01:46 AM
  #38
Wheatley's Avatar
Truck Sponsor
If you are going to try to read plugs,invest in a moroso magnifying glass with light made for this.
Cut the threads to so you can see the base fuel ring.
Tydriver
45
Oct 23, 2015 09:19 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
FormulaZR
Sep 14, 2015 05:23 PM
cousblake11
Sep 9, 2015 06:52 PM
