NGK plug questions
Old Jun 10, 2002 | 09:54 AM
primetime's Avatar
Default NGK plug questions
Which is the superior platinum plug? G-Power or VX? http://www.ngksparkplugs.com/product...s/platinum.asp
Not sure which one to choose for my 99 Siverado 5.3? Thanks for the help guys.
Old Jun 11, 2002 | 12:06 AM
Puffnstuff's Avatar
Default Re: NGK plug questions
I've been looking at those plugs as well. Bosch doesn't seem to fair well in my 5.3 so I'm looking for something else to replace them with. I'd definately stay away from multipronged plugs in the 5.3. I had the +4's in my truck and the unused prongs fouled up and it made my engine miss at 4K rpm plus gave it a dead spot from 4-4.5k rpm.
Old Jun 15, 2002 | 06:08 PM
Puffnstuff's Avatar
I've pretty much made up my mind that I'm going iridium this next time. It's down to between the ngk tr55-ix and the denso IT16 which has a u groove in the ground electrode. I'm leaning heavily towards the denso even though it costs twice as much as the ngk. That should stop the eroding electrode problem that I've had with the bosch platinums which caused my gaps to grow in a very short time.
Old Jun 17, 2002 | 11:47 AM
bgreen's Avatar
Aren't the regular TR5/TR55/TR6's working out for you guys? LS1's seem to have no problems with those plugs, even on nitrous & blowers..
Brian Green
89 TTA
01 Jeep TJ - 5.3 going in it in the fall
Old Jun 18, 2002 | 12:38 AM
KRAZY J's Avatar
Hey Primetime, about every how many miles would you say the plugs need to be replaced. Same with the wires. I have 38k and still have stock wires and plugs, mostly because I have never had any problem. Thanks
Old Jun 18, 2002 | 12:50 AM
GREGGO's Avatar
I had TR5's in mine for 30k gapped at .050. When I canged to TR55's, the gap was at .052. I generally change at 30 to 40k just because they are so cheap. I don't see the need to spend $8.00 a plug or more when you can get them for $2.00 each.
The_W
Oct 28, 2015 09:00 PM
713truck
Aug 18, 2015 09:32 PM
USMCvet0311
Aug 1, 2015 07:45 AM
Ls3silverado
Jul 31, 2015 04:22 PM
