newd plug wire question
Old May 13, 2006 | 05:29 PM
Colby 04's Avatar
Originally Posted by Soon2bSpooled
i'll just pull hard, try not to break the stuff i keep, then grease the new ones, what if i dont grease it? will it just be hard to pull off next time?
grease them
Old May 13, 2006 | 05:46 PM
will do
Old May 13, 2006 | 05:48 PM
TouchOfEvil04's Avatar
Just grease em its a pain without it and even then its still hard...
Old May 14, 2006 | 12:46 AM
Hydramatic's Avatar
Definitely grease em.
However, faced with the same problem, I tried something that made my life a WHOLE LOT EASIER. Do you still have the metal boot protectors on the spark plug end of the wire? Using pliers, carefully pull on the little heat-shieldy thing, and the plug pops right off. When puttin' them back on, press the shield and wire onto the plug until it pops again, and you will suddenly find that the plug wire is back in it's "immovable" state. Try it, I promise you'll be like, "OMG why wouldn't it come off that easy before?"
Old May 14, 2006 | 01:20 AM
yes i do have that metal thing, so are you saying take some vise grips to it and pull on that shield and it should come off easy? pull towards the end by the engine or the end closest to you? i might just tug on the wires and trash all that crap to make things carefree and easy. with the new wires will i need that heat shield thing?
Old May 14, 2006 | 03:51 AM
You don't have to use the heat shields but if you ahve LT's are plan on gettin them i'd keep them because the heat from LT's is extreme.When you grab the metal shields around the wires it will be easier but i'd grab as low as you can that way its closer to teh base of the plug and comes off easier.The ones in the very back are a pain in da ****....espically the driver side on with LT's lol.....
Old May 14, 2006 | 10:08 AM
thanks for the info touch, i dont have LT's yet so i guess it wont be such a pain. i'll keep the heat shield.
Old May 14, 2006 | 11:02 PM
jj2sxe's Avatar
I read this thread a little too late. Just a couple days ago I installed MSD 8.5mm's and I never greased them before the install. On a scale of 1-10 how hard will it be next time?
Old May 14, 2006 | 11:03 PM
Like a 9.9.....it will be a bit more difficult next time around....I would go ahead and pop em off and add some now....
Old May 15, 2006 | 12:52 AM
Hydramatic's Avatar
Yeah. Don't be like me and spend an hour trying to rip melty boots off of a 4.3L and cutting your hands to shreds...
Don't ask..
rojeho
Aug 8, 2015 07:20 PM
USMCvet0311
Aug 1, 2015 07:45 AM
sauldgold
Jul 23, 2015 02:15 PM
bsgiffor
Jul 19, 2015 11:14 AM
