newbie to compression...241s on a 6.2?
Old Aug 25, 2010 | 06:12 PM
01 BERGER CAMARO SS's Avatar
Default newbie to compression...241s on a 6.2?
ok, my cuz crashed his escalade and the insurance let him keep it cheap. He let me have the 6.2 complete. I want to install this on my 09 but need to swap out the heads to the GenIII style cause of the intake runners. I have ported 241's that were banched and flowed 295 at a 600 lift. Now, with a stock MLS GM head gasket what would be my compression? I will also be installing LS7 lifters and Zr1 camshaft..
P.S. I have a Roush TVS1900, thous the reason for needing to swap the heads. Would love to keep the l92's..lol..
Old Aug 25, 2010 | 06:26 PM
Gh0st's Avatar
Jedi Master
I would advise a set of 243 or 799. Do not put 241 heads on there.
Old Aug 25, 2010 | 07:19 PM
Mr.Nobody's Avatar
243's,
Old Aug 25, 2010 | 09:30 PM
stock 243 flow less than these ported 241's...Im not going to spend 400 bucks for heads that will flow less..Come on guys just need to know if im going to be ok as far as compression
Coban's Avatar
Using a CR Calculator that is easy to find with a search online, I get:
241 - 10.9 CR
243/799 - 11.2 CR
317 - 10.3-10.4 Cr depending on where the CC size comes from
These are assuming stock .051 gasket with .010 out of the hole.
Old Aug 26, 2010 | 12:04 AM
LightFighter's Avatar
those stock L92 heads flow.... 330 @ .600 lift from the factory!!! find a new style intake and leave the stock heads on it!!! .... now I know you have the SC......... but you should beable to find a lower intake for that blower to match the L92's
and if you have to go with the old style head then the Lq9 head will drop your compression a bit over the Ls6/LS2 head I believe
Old Aug 26, 2010 | 06:14 AM
Quik's Avatar
5 year bitches!
since yu have the parts go ahead and use them. youll be fine, if that blower makes decent power youll be fine
Skip Fix
22
Jul 9, 2016 07:08 PM
Jonblarc7
40
Dec 23, 2015 10:15 PM
slocaddy
Sep 25, 2015 12:42 PM
scooter k
Sep 16, 2015 10:32 PM
