new waterpump FYI
Old Feb 12, 2007 | 12:15 AM
stone150's Avatar
Default new waterpump FYI
you might remember my post about my water pump
1st post
but i replaced it and the design is different, it comes with seals and a new thermostat, i insatalled a 180 thermostat on my old pump a month ago, and when i went to put it on the new one, it dosen't fit, but the truck runs at the same temp that it did with the 180 stat, so gm must have made a new stock thermo. so don't expect to use your oldones if you replace the waterpump, with a new gm one
also the bolts that hold the thermostat in a pure junk, not heat treated. broke one off, reused my old ones
Old Feb 12, 2007 | 11:25 AM
BLACK04VHO's Avatar
Yeah my classic 07 came with a new design water pump. Found out when they installed my radix and it didn't match up. So they had to pull the brand new one off and swap out for an oder model to get it to work properly.
Old Feb 12, 2007 | 05:32 PM
nightrunner's Avatar
Mr. Obvious
the new tstats are 183 degree FYI so not much difference
Old Feb 12, 2007 | 08:04 PM
stone150's Avatar
that is about what i figured.
Corvette454l88
Sep 1, 2016 01:24 AM
therock
Jul 25, 2015 09:23 AM
moregrip
25
Apr 4, 2005 10:26 PM
DoverJ1W
Sep 6, 2004 09:40 PM
OBXMarine
Feb 25, 2004 07:42 AM
